lol. Hey is anyone going to the Brissie autosalon this weekend? is $20 entry, probably the same for parking :) starts at 10am and finishes at 7pm. 5:00 is normally when the "big boys shootout" happens. that is were engines are made famous or bite the dust :(
Edited by SoarerGT-T Cruiser
i ended up going the silvia... i tried a few gtr's and they were ok.. but this s15 i got pulls hard... shes got a lot of ponies under the bonnet and a pleasure to drive.. im in love..
Tis Blue with a midight purple ( almost black) bonnet with cool sparkles through it.
18" Rims with BFG's on it.
Engine Mods:
Greddy FMIC
Apexi Power Intake
Greddy Fuel Regulator
Greddy ProfSpec II EBC
Apexi 740cc Injectors
New Piping ( stainless and rubber).
Apexi Power FC + Controller
Xforce 3" Turbo back & manifold upgrade
Aftermarket Fuel Pump
Apexi Turbo Timer.
New NGK sparkys
Various Gauges ( boost / airflow & some other one that has numbers and stuff lol)
Driveline
Excedy Single Button clutch ( full system, bloody hard as, its either in or out lol)
Brand new Slotted RBA rotors and pads.
Exterior Bling.
Scissor Doors (wooooot)
5 Point Security system
ICE
2 x TS-SW1241D (pioneer) Subs
1 x T20001bd Amp ( rockford)
1 x T400-2 (rockford) for the splits
1 x MAX686BT for the deck, quite a nice setup actually..
Tis very nice!!
heres some pics, ill get some more soonish.
It goes brooooooooom very very very quickly
these pics dont do it justice... it's in mint condition!!
Engine Mods:
Greddy FMIC
Apexi Power Intake
Apexi Turbo Timer.
New NGK sparkys
Driveline
Exterior Bling.
ICE
Tis very nice!!
Right.... very random...
Engine Mods:
Greddy FMIC
Apexi Power Intake
Apexi Turbo Timer.
New NGK sparkys
That pulls harder than a GTR???
I still got a stagea which meets 2 of the requirements
1. Nissan
2. Rb powered
i also had an r33 before this, but without trying to defend myself theres many many many people on this forum without a skyline. I love my s15 over my r33 anyday.
And yeah this car felt better then the gtr's i test drove.. i could only afford to look at r33 gtr's..a r34 gtr is a different story..
And i put this post in as a few pages back we were talking about what i was going to do (either get a gtr or an s15).
Was either get a really nice s15 or a bottom of the range quality GTR.. i chose the first option
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
