Alright sunny coast, now is your time to speak up and tell us – SAU what the coast would like to see from SAU. We’re about to release the 2009 events calendar and would love to here whats on every ones mind:
More centrally located events? Social? There is an abundance of you skyricer’s, so let us know what you want from a car club.
Alright sunny coast, now is your time to speak up and tell us – SAU what the coast would like to see from SAU. We're about to release the 2009 events calendar and would love to here whats on every ones mind:
More centrally located events? Social? There is an abundance of you skyricer's, so let us know what you want from a car club.
picnic's along the beach :thumbsup:
maybe some cruises up this way through out the year, with a BBQ or something at the end, also i know you hold skid pan days up at gympie so thats also another good one.
um we could have a meetup cruise to the noosa hillclimb maybe.
just a few things we could do up this way
I might give ron hill a go. due for my service again and my local guy is away for the Christmas holidays. he appears to have agood rep :(
Hey Allara,
If your local guy is away try AM Auto if you're after a service. They specialise in Subaru's but service any kind of import you can throw at them. I've had my R34 serviced there twice - I also had them replace my timing belt & water pump and they do good work. They also custom fabricate almost anything you like - they're putting a 3" turboback with custom front pipe onto my '34 today.
They're down in Project Avenue - let me know if you're interested and I can forward on the details.
Sean
Edited by R34mac
Hey Allara,
If your local guy is away try AM Auto if you're after a service. They specialist in Subaru's but service any kind of import you can throw at them. I've had my R34 serviced their twice - I also had them replacee my timing belt & water pump) and they do good work. They also custom fabricate almost anything you like - they're putting a 3" turboback with custom front pipe onto my '34 today.
Sean
Hey sean,
Your not wrong there mate, AM auto are 1 of the best around, ive seen the work they put out and they really know their stuff.
+1 AM AUTO
Hey Allara,
Sean
Hey cheers for that Sean.
Might go have a look...never knew they were down there and i have lived here my whole life lol.
Allara :D
Hey guys, I think i emailed most of you who were coming along this sunday for the christmas cruise. But in case i hve missed any of you i just wanted to leys know we have been forced to post pone due to bad weatehr predicted at the destination. So it will probably turn into a new year cruise. :)
We will posting up teh new information within the next week or two :P
And beforei forget to all of you i hope you all have a merry christmas.
yeah, the destination at this time of year is usually plagued with storms no matter what weekend u choose, its luck of the draw. so maybe some where a little closer then that way if it does turn bad, u can always get home quicker or atleast to some where undercover.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
