Ok, I couldn't find anything of value so I thought I would ask how the T70 turbo's go with an RB25 motor?
.82 exhaust size with a 60.5mm front wheel is the one I am looking at.
I am ok with a little lag, ie it starts boosting at 3500rpm.
but do they come on at 5k or something ridiculous?
Not after opinions on the quality of a T70, just what they are like on a 25 please.
https://www.sau.com.au/forums/topic/140893-t70/
My mate one tuned one for a customer rb25det and it made 420rwhp on 19 psi. it made full boost at around 4000rpm
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624026
that's the answer I was hoping for.
have got 550cc injectors, haltech ecu etc etc, so I figure if I see full boost by 4k and I am making high 200rwkw's, they must be a good "cheaper" turbo then.
cheers
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624032
420rwhp is about 300rwkw :sick:
cheers
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624074
assumptions?
Why do you think I am asking the question here?
Got an answer that relates to an answer I got elsewhere that they are pretty good on a 25, but laggy on a 20.
The 20 I speak of made 24orwkw on 19psi.
I plan on running 16psi in the 25 and anything between 250-300 rwkw will be a big jump from 204rwkw that I had last tune.
Saying that, it's more a question about lag.
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624080
yep thats right boosting at 4800, i had power fc, the usuals no internals, too get it to boost early like 4k you would need a good set of cams. and im now running a gt3040. your better to save your money and do the job right first than waste $500 or however much they are, i learnt the hard way money down the drain and i had a lag monster.
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624094
gt3040 or a gt3540, is a million times better. you can choose your ex. housing size for your response you want. there excellent quality, ball bearing, water cooled. i really wish i went that to start with instead of trying to get cheap power that just cost more in the end.
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624119
I had one also on my rb25 and didnt see full boost till about 4800-5000rpm...was a mass lag monster. On 17psi i made 350rwhp with supporting mods and all, no cams though.
then it ceased up cause the shitty oil line i used got blocked up and starved the turbo of oil.
Now have a gt3040 with .63 rear, much much better :)
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624947
i got a friend who has one of these t70 turbo's off ebay..its making around 293rwkw @ 18psi,bit of a lagg monster but once it comes it comes on HARD..has been for last 5months..never missed a beat..i dont understand how u guys break them so easily?
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2627344
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
    • I like their veal scallopini.
    • Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
    • Thanks for coming back to post the update, maybe it will help out the next person!
