Ok, I couldn't find anything of value so I thought I would ask how the T70 turbo's go with an RB25 motor?
.82 exhaust size with a 60.5mm front wheel is the one I am looking at.
I am ok with a little lag, ie it starts boosting at 3500rpm.
but do they come on at 5k or something ridiculous?
Not after opinions on the quality of a T70, just what they are like on a 25 please.
https://www.sau.com.au/forums/topic/140893-t70/
My mate one tuned one for a customer rb25det and it made 420rwhp on 19 psi. it made full boost at around 4000rpm
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624026
that's the answer I was hoping for.
have got 550cc injectors, haltech ecu etc etc, so I figure if I see full boost by 4k and I am making high 200rwkw's, they must be a good "cheaper" turbo then.
cheers
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624032
420rwhp is about 300rwkw :sick:
cheers
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624074
assumptions?
Why do you think I am asking the question here?
Got an answer that relates to an answer I got elsewhere that they are pretty good on a 25, but laggy on a 20.
The 20 I speak of made 24orwkw on 19psi.
I plan on running 16psi in the 25 and anything between 250-300 rwkw will be a big jump from 204rwkw that I had last tune.
Saying that, it's more a question about lag.
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624080
yep thats right boosting at 4800, i had power fc, the usuals no internals, too get it to boost early like 4k you would need a good set of cams. and im now running a gt3040. your better to save your money and do the job right first than waste $500 or however much they are, i learnt the hard way money down the drain and i had a lag monster.
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624094
gt3040 or a gt3540, is a million times better. you can choose your ex. housing size for your response you want. there excellent quality, ball bearing, water cooled. i really wish i went that to start with instead of trying to get cheap power that just cost more in the end.
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624119
I had one also on my rb25 and didnt see full boost till about 4800-5000rpm...was a mass lag monster. On 17psi i made 350rwhp with supporting mods and all, no cams though.
then it ceased up cause the shitty oil line i used got blocked up and starved the turbo of oil.
Now have a gt3040 with .63 rear, much much better :)
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2624947
i got a friend who has one of these t70 turbo's off ebay..its making around 293rwkw @ 18psi,bit of a lagg monster but once it comes it comes on HARD..has been for last 5months..never missed a beat..i dont understand how u guys break them so easily?
https://www.sau.com.au/forums/topic/140893-t70/#findComment-2627344
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
