Give regency a ring.
I did some time ago and was told you are not allowed to touch anything that is concerned with the bov, being; the bov its self, the cross over pipe, the pipe that runs from the bov to the turbo inlet pipe AND the turbo to afm inlet pipe.
https://www.sau.com.au/forums/topic/141001-bov-legal-in-sa/#findComment-2625712
Thanks i just imported an r33 gtst and it has a blow off valve which you can hear quite easily i haven't had a chance to look but i assume its after market i wondering am i going to get defected for it should i get another quite one cheers
https://www.sau.com.au/forums/topic/141001-bov-legal-in-sa/#findComment-2625769
Yeh ive got an R33 Gtst and its got a stock blow off valve and an apexi pod......u can very easily hear the BOV noise, sounds sweet! but yeh its probably a stock BOV coz wen u import ur car and it gets complied dont think defectable mods to ur car are allowed. :rofl:
https://www.sau.com.au/forums/topic/141001-bov-legal-in-sa/#findComment-2633109
yeah, crankcase emissions.
More so how it plays with the afm and dumps fuel.
I blocked my bov off when testing if it leaked and found it would pop and fart & occasionally stalling.
Venting the air would play havoc with the air metered even more so.
https://www.sau.com.au/forums/topic/141001-bov-legal-in-sa/#findComment-2633946
I asked regency about aftermarket plumb backs.. I was told no, its part of emissions so I can't touch it.
This was some time ago.. Give Regency a buzz and see what their stand is on it these days.
Just block the std off and enjoy quicker turbo spool and almost zero lag between gear changes.
As mine spools so soon it caused a few driveability issues but nothing I couldn't work around.
https://www.sau.com.au/forums/topic/141001-bov-legal-in-sa/#findComment-2634556
um...a BOV (or recirc. valve) increases response in some cases, yes the air is released and that air does need to be replaced causing lag, but at the same time, the air not being vented without a BOV is forced back towards the turbo going the oposite way to the turbo causing the turbo to slow down quicky and to spool to the turbo up again takes time, creating lag.
https://www.sau.com.au/forums/topic/141001-bov-legal-in-sa/#findComment-2634634
