Hello all,
Well i've been searching and learning what to look out for when getting an R32GTR. I've just got two small questions: -In one of the threads i noted that the "earlier GTR's had oil probs due to crank collar design". My question is -how early are we talking? Was it just with the 89 models? The one i got my eye on is a 90 model...
Also, as i've never actually felt it before -so wats the tell-tale sign the gearbox synchros are on their way out? Im presuming its just a bit hard to find the gear????
...feedback appreciated :P
https://www.sau.com.au/forums/topic/141039-so-im-getting-a-32gtr/
A 1990 model has the same oil pump drive as an 89. They are fine unless you habitually launch the car from 6000rpm+. Then they tend to break. They were revised in about 93. There is no actual difference in the oil delivery between the two pumps.
You will hear a synchro graunch as much as feel it. It feels like two gears grinding against each other, which oddly enough, it is. You will still probably get it in gear.
not sure about your oil problem question wouldnt mind to know myself cause ive got a 90 model
with the syncros my old box was losing them and i only noticed it when doing high rpm/quick gear changes just ground the teeth a little bit and needed slightly more force to put into gear at these times
other than that changed fine thats the tell tale sign as far as i know
RellikZephyr
Don't rush into buying an R32 GTR especially if importing. Most R32 GTR buyers now will look at late 93 - 94 Vspec models with minimal mods. If there is no service history you may need to change a few things like water pump, timing belt and the crank collar ike you say.
My gears are always a bit tough to grab when cold (especially 1st) and 5th always grinds if I just gave it a bit of stick in 4th, but its ok if I hold the clutch for a few seconds and slowly engage 5th.
The oil collar was updated on late 1994 models. Earlier models all had the 'design flaw'.
Not quite correct. I have seen a number of motors where the oil pump drive has completely rounded off on the corners. Its just daily wear and tear and it does happen without continually launching the car.
Hello all,
...feedback appreciated :whistling:
early GTR's didn't have "oil probs due to crank collar design". The crank collar is a weakness if the car is bounced off the harsh factory rev limiter too much it can break and then there's no drive to the oil pump - which means one stuffed engine (not to mention two turbos). if its not broken, there are no problems caused by the crank collar design, and if you stay off the rev limiter there's no reason to expect any problems. AFAIK all R32's have the same crank collar oil pump drive except for the uprated N1 version.
all GTR's have oil problems with running at constant high rpm (ie track work) with too much oil supply to the overhead parts. you will be able to find heaps of info about this posted by SK.
and all are suspect for oil surge during track work. some say even a hard launch on the street can cause oil surge! common advice to prevent this is to use an extral litre of oil.
obviously if the engine ever comes out (ie to change turbos), it would be money well spent to fit the N1 oil pump and drive and a sump baffle kit. otherwise, be careful to stay off the rev limiter and use an extra litre of oil.
Edited by hrd-hr30
So does that mean that my current 1993 R33 GTST has this "design flaw"????
Yep, i've definately seen this in many threads on the forums....
Thanks for the info pplz.
The GTR's i got my eye on are already in Melb which will give me the advantage of getting a compression test and leak down test just before purchase. Although i will loose a few $$$ buying one that's already landed as compared to importing myself, i think its worth it if it insures i dont get a dud.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
