  • Replies 45
jun ones arent 300 bux...theyve come way down since then... about $185.00 delivered from nengun now. We got ours from Hi Octane about 6-8 months ago for about $250.
Edited by r33_racer
We have used the Pro Engines crank collars on 10 or so RB30's and not had a single problem. They are a good sweat fit on the crank and run tight tolerances (clearance) for the N1 oil pump drive flange. Excessive clearance/crank flange wear is one of the causes of oil pump rotor failure.
:O cheers :rofl:
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
