Hey guys,
I happen to have a set of R32 GTST type m front calipers and rotors at home which im not going to use on my 180sx anymore (going to use R33 stuff insteed)
Anyway i have a R32 GTS as my daily and i wanted to know what exactly i needed to change it from 4 to 5 stud??? As the CA brakes just dont cut it...plus i may do turbo conversion one day!
Im guessing ill need:
R32 front 5 stud hubs
R32 backing plates
do i need anything else???
Also what is needed for the rear? I think it already has the drum handbrake.
thanks
Edited by hawker05
https://www.sau.com.au/forums/topic/141371-r32-gts-4-to-5-stud-conversion/
  • 3 weeks later...
ull need the 5 stud hubs but make sure they are GTSt not GTS4 other wise you'll need to change you rear shocks
you'll need GTSt brake lines too
How about R32 GTR parts?
R33 GTR???
R33GTS????
We have the same pending question as our project approaches completion.
Is it possible to use the GTR gear?
Thanks in advance.
Rob
Is it a must to convert to 5 stud if you whack a turbo on a gts? couldnt you just redrill z32 300zx brakes or something to fit and leave it as 4 stud?
Hey mate i dont think it is i have a r33 gts which has an rb25det in it and it just has r33 gts-t front brakes, not sure about the back and still has 4 stud pattern.
Thats what i like to hear lol, less money for me down the track. Theres silvias and 180's out there with 4 stud which have monster engines in them and they are fine so i dont see why a 4 stud skyline couldnt stay that way provided it had sufficient braking power.
Sorry for kind of hijacking the thread mate, continue.
Cheers, Steve
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
