Hey guys,
Just wondering whos used sound deadening in there skyline!
Im getting my doors done but where else have you found to have a noticeable impact on cabin noise.
I have a Series 2 Gts-t coupe.
Thanks!
I have put dynamat extreme on a few ee series 2's, if you do it properly, i.e. on the inner and outer door sheet metal, you cant go wrong. It will make your doors sound firmer, as well as make your door speakers sound awesome. To give you an idea, the pioneer splits in my doors put out more bass than the kenwood 6x9s which I have mounted in an MDF parcel shelf.
https://www.sau.com.au/forums/topic/141591-sound-deadening/#findComment-2637763
*sigh* still to do mine. I have a Dynamat extreme kit, so it should do two doors.
Anyway.. my boot rattles with a single sub. I thought it might be the keylock part, which has some play in it... in which case I might just lather it in some thick grease instead. (from the inside of the boot-lid.. behind the lining if you have it)
https://www.sau.com.au/forums/topic/141591-sound-deadening/#findComment-2637988
under the rear seats is a source of noise.
the doors give you the best bang for your buck but if you have time and money that is the next place to get stuck into.
Rear quaters/doors if 4door and boot are both good places to SD. I had a bare boot and after SDing the boot bottom and wheel arches it made a fair bit of difference.
Edited by rocketboy
https://www.sau.com.au/forums/topic/141591-sound-deadening/#findComment-2640445
So it is quite good to do eh?
Seems a few people are getting tighter panels and increased dB from doing the doors and boot.
yep, fixes a few things - lack of bass for one in the doors.
https://www.sau.com.au/forums/topic/141591-sound-deadening/#findComment-2641761
this is one of those how long is a piece of string questions, but roughly how much weight are we adding to just the front doors? 5kg?
I'll say this - a bulk pack (9 sheets) is 18kg. do the math off that. doors on a skyline takes 4 sheets.
https://www.sau.com.au/forums/topic/141591-sound-deadening/#findComment-2642118
Say chris.. do you reckon the dynamat packs are worth the money in your opinion? because, i've got a boat load of deadening packs i bought from a car shop years ago (it's basically just adhesive with some foam). and i've also got a few litres of septone brush on deadener (which smells like fish oil, but seems to work well on my boot). but then again, they're all available to me at no cost... whereas a decent deadening pack to do my doors, floor, boot will set me back a few hundred.
Edited by Howie
https://www.sau.com.au/forums/topic/141591-sound-deadening/#findComment-2642136
I got the dynamat bulk pack off ebay for about $200, off quicksmarttechnology i think there name was. I did my doors and I have plenty left over to do my boot. From what I have seen and heard, the brush on stuff can be a pain and pretty messy, dynamat is pretty much like putting contact on your doors (not really as easy)
https://www.sau.com.au/forums/topic/141591-sound-deadening/#findComment-2642243
may want to do the math here but its $248 shipped. now I do these things at $243 shipped all day long. postage is not $39 to ship it oz wide- its roughly half that.
that said its application is pretty much like contact paper only a bit thicker.
howie,
if you haev access to teh foam type do it. the spray on is messsy and not as effective. good for rust though.
https://www.sau.com.au/forums/topic/141591-sound-deadening/#findComment-2642434
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
