hi im in the process of rebuilding my engine and am undecided as to what path to go down. ive heard differant information about this (25+26internals) but i want some concrete info!
QUESTION: can you put a rb26 crank, rb26, rods and rb26 pistions into a standard rb25 block? and increase the capacity???
PROBLEM: this longer stroke will obviously smash the valves with a standard head gasket, BUT how big of a gasket or spacer plate do you need to prevent this???
PROBLEM: whats teh diff between the rb26 pistons and 25 pistons?
OVERALL: is it worth it??
thanx peeps
Should of asked this is Performance section
anyways
You can run the Crank Rods and pistons.
There is no Stroke difference only Piston sizing by .5m from what i remember.The RB26 top and Rb25 tops are different and i would say if your rebuilding it you miles well stick with
Rb26 crank
Rb26 Rods (they are Stronger)
Rb25 pistons (just oversized 20-40 thou)
What are you using the motor for and what are your future plans
thnx for quick reply.
i might start another thread in performance section aswell.
engine is for some responsive street work, looking at 400rwhp reliable, definately forged set up with pistons and maybe rods.
the reason why i ask this, my first plan was to build my 3.0litre with twin cam, but theres some good priced pistions and rods for sale ere and im thining of gettin em.
will doing the 25/26internals increase capacity?
will using 26 pistons not work with the 25 head?
I have a couple of questions for you
1) what were you useing the car for exactly (Road + Drift,Drag,Circuit)
2) what sort of money you want to spend
3) who is doing the work
4) where you from
1) hard road use
2) ive got 3grand to spend on engine parts, (already got 2vvt r33 heads, 2 rb25blocks, 1rb30 s2 block n loads other parts) so dont need to buy that, already got huge T04e, ecu, ect... engine parts which will include, pistons, bottom end rebuilt kit, head gasket, head work(if money allows then bigger valves n Hbeam rods)
3) ill be doin a bit of work to save labor cost, and my mate diesel fitter is gona do most of it.
4)im in perth, was gona get maybe applied engineering to fit the head, after doing minor port polish and re-con with new valve spring (and bigger valves if money allows)
Rb26 internals are a straight swap into an rb25 motor.
The bores are identical.
The rods are the same dimensions but rb26 rods are stronger.
The piston pins are closer to the top of the rb26 piston to compensate for the longer stroke so there is no problem with valve clearance and the resulting compression ratio of about 8.5:1 is ideal for most mild applications.
By the time you buy good rod bolts and prep the stock rb26 rods you may as well buy eagle rods.
To do this rebuild justice you will need a lot more than $3000
is it worth it tho? has anyone done it and what have they found, pros and cons? or do u know of anyone whose done it?
or shall i just do the 25/30.?
so you guys r saying there is absolutely no clearance issues with these internals?
i dont see how 3gee will get me half way??? theres a few sets of used forged pistons on sau for bout $700, rods $800 new, gasket $500, bearings, seals ect $400... so far thats about 2.4? and what eva it cost for honing n acid bath ect, ill just need a bit more for head work i think. and labour is a favour from a mate. its obviously not a 10grand rebuild coz thats not realistic for ME just yet and probably not necessary for MY 100% street use, just a bit better than standard, strong an reliable.
what cost have i missed?
cheerz guys
Edited by humz
The crank will need machining + collar etc... if you dont have the R33 crank already
Realistiaclly you wanna be putting then N1 pump
It almost works out cheaper to just get a new crank if you have the R32 crank ... so $110, but nissan dont have any at the moment :D
Basically yeah, by the time you fart around with the R32 GTR one, the R33 one comes in cost-wise very close, and its new :D
Depends what you want, a 25/30 could be better, it might not.
I havent done the conversion myself, but i've had old RB25 & recently my RB26 built...
And i've pondered/gone over these details myself many many times :no:
For me, i was thinking about a 25/30 and a 26/30 aswell, but i ended up opting for the displacement i had to begin with based on what i want, and the characteristics i wanted the car to have
  • 4 years later...
what type of machining will the 32 gtr crank need, is there a particular measurment or anything.... ive got one that i wana use in my 25, also got 26 h-beam rods and getin a set of 26 forged pistons...
Sure hope it's enough to reach 88mph
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
    • @Stringycheese  Have you only gone to the one blue slip workshop?  There will be a heap of them where ever you live, good odds that the next place you go to will pass the car.  Unfortunately (or fortunately?) every blue slip / engineering workshop will be different and will be happy passing or failing different things - despite working from the same set of rules. It's kinda like 2 lawyers arguing over a piece of legislation, each saying their interpretation is correct. Might seem strange that this happens when it comes to getting a modified car passed, but this is very much a thing. A big part of the game is finding an engineer / workshop that is on the same page as you.
    • Bah. I daily mine. ~60km per work day, 10-12 thousand km per year. What's the point of having a dirty old Datto and leaving it in the shed. It needs to be driven and enjoyed while the govco allows us to do so. It will only be a few years before we're forbidden to even start up internal combustion engines.
    • Judging by that spring perch and the normal looking spring on it - not a coilover. Well.... it is a coilover, just a stock format coilover, rather than what everyone calls a coilover.
    • Yes it is. We get stock from Nismo directly. I'm happy to take photos/video of it as proof before I ship it with timestamps or whathaveyou.
