I have organised a group buy through 6boost on calaisturbo.com.au for his manifolds. these can either be hi or low mount rb(20/25/26/30) manifolds. the flange on the manifold can either be t3 or t25. Fot those of you with other than rb engines contact me if you wish for a manifold and i can work out a price and include you in the group buy.
This group buy is set end on 30th November 2006 where the manifolds will be ordered and when completed dispatched. all that is required is a $100 deposit by the 30/11/06. Depending on numbers it will take approximately 2 weeks for your manifold to be completed.
These manifolds are hands down the best on the market. i have looked into and spoken to people that have used his manifolds and have had only 100% positive comments. Below is a link to his thread on calaisturbo where you can read up on the product.
http://www.calaisturbo.com.au
The normal retail price for one of these maniflds is $1200, which comes with a fitting kit with turbo gasket and new studs and nuts for head and turbo flanges, and manifolds also come with a lifetime warranty.
As for a group buy price:
- 3 manifolds = $1000
- 5 manifolds = $900
Any questions just post up here.
Boro.
https://www.sau.com.au/forums/topic/141777-6boost-rb20rb25det-manifolds/
flysky and woolls are you both in? cuz that makes 3.. that is the minimum requirement. let me know what you guys are after. manifold for what engine/flange type, external/internal gate etc.. thanks.
manifold.doc
Hey I would like one for a top mount rb25 with external wastegate outlet on it like this one here.
How much is postage? Can i pick it up? With T3 flange please.
Edited by Nabil
me too in a low mount
I've had a small discussion with 6boost some time ago regarding the making of a lowmount manifold for the dohc. He wasn't interested as he couldn't use his collector. Such a pitty as any low mount he could put together would be better than the current ebay types. I suggested something along the lines of a HKS manifold design but he just wasn't interested. :)
So many of us DOHC heads buy those ebay things too, if only something in low mount was available.
:P thanks for letting me know cubes
waz. no i dont have pics. i have messaged 6boost but have had no reply. if you are intending on keeping stock turbo not too much point in getting one of these manifolds. im not 100% sure he will maintain stock positioning with the manifold.
I've had a small discussion with 6boost some time ago regarding the making of a lowmount manifold for the dohc. He wasn't interested as he couldn't use his collector. Such a pitty as any low mount he could put together would be better than the current ebay types. I suggested something along the lines of a HKS manifold design but he just wasn't interested. :(
yeah
I had a low mount ordered but was sent back due to flange facing up instead of away from engine... so isnt really possible with their collector. :P
Someone should take on the HKS design..
yeah
I had a low mount ordered but was sent back due to flange facing up instead of away from engine... so isnt really possible with their collector. :(
Can you still buy hks low mounts for rb25?
do you have any picks of the low-mount type for an rb20 with T3 flange (so basically setup with turbo in same position as stock etc.)
cheers,
Warren
would be very interested in seeing a pic of the low mount rb20 with t3 as well... runnning a trust td-05 kit though :)
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
