Im selling my 1989 R32 GTR, engine has a dropped valve - so will need a rebuild, it's registered til Jan 07 and besides the motor, it's all good. I bought this car pretty much as is so not too sure about somethings. But I know it looks tough and went hard - below are the details.
Price Drop: $13,900ono
Condition: Good condition, spoiler has paint cracks and front left fender has no shine left but other than that no looks problems. seats are in perfect nic, no cracks in the plastic/dash/etc. all electircs work. no rust - there is an AC problem though?
Engine: RB26DETT (off course) dropped valve needs rebuild (approx $5 - $6k+)
Turbos: 2 x new last year - slightly larger but sorry I don't know what they are exactly - will try and find out.
BOV's: 2 x Bee*r one set for low boost and one high
Intercooler: all HKS plumbing, not sure which brand (HKS?)but bigger intercooler
Gearbox: 5 spd - good cond - not notchy, standard clutch I think
Diffs: Standard, no problems. torque splits well.
Brakes: front standard everything, back standard calipers and cross drilled rotors
Wheels: 17" - Japanese Brand? - good rubber
Exhaust: 3" + HKS Super Drager muffler
Suspension: Tein coil overs (Handles like a go kart!)
Steering Wheel: Bee*r (no that's not a NOS button in the pics - it's the horn)
Dash: Veilside 340kmph
Other: Turbo timer, HKS boost controller, CD/MP3, alarm/imobiliser
Performance: 12.54sec at Kwinana on street tyres and lots of wheel spin.
Contact: Simon 0409 105 569 or [email protected]
Edited by OGzilla
https://www.sau.com.au/forums/topic/142111-for-sale-r32-gtr/
Nice car champ unfortunately GTR rebuilds are 10k plus not including turbos ;/ if your lucky, I just rebuild mine
10k! I just got mine priced up - $6000 with metal head gasket and forged pistons
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
