Rda Rotors Group Buy - 5th & 6th Batches
  • Replies 113
That's because NONE have been shipped yet.
They were just doing the invoice today and should be charged to my card account today.
Sorry for the delay, as they're doing the invoice today, I believe they should have 7693 & 908 in stock today...
Got my rotors today, 7701G. Thanks rs73. BTW, how do I add a +1 to your trader rating?
really? woah good on ya. still waiting on my coz i have an annual cruise to attend to!!
my rotors were in stock so i assumed they sent it last week :S
wish it could be earlier. last week they wanted to wait till all rotors in stock, until I found out about the shortage issue, and requested them to try shipping those orders without 7693 or 908. so I reckon yours should be arriving anytime soon...
vaughan, I think feedback can be enter via user's profile. click username then goto comments section.
for those wanting to be in batch 6, i'l check with rda what's their stock status with 7693 and 908, as these 2 seem to be the popular ones here.
Hey mate, just wondering..
If i can get a set still with this group-buy.. Just noticed the date that it ended.. Willing to get the payment done asp..
1. R32 GTS-t/Z32 300ZXTT: F=909S 280mm RRP $170
Fronts only..
Thanks mate!
Fronts only..
Thanks mate!
+1 for me and maybe grooved depending on groupbuy price.
cheers
Patrick
ok, finally after a long wait they got the rotors in stock and charge my account today, and I can see some ofyou start receiving the rotors today, which is good.
I will see if they've shipped your 7500S, xolent.
for those who wantrotors, i'm waiting for their reply in regards to 7693 and 908 availability before christmas. if abundant I can start again asap.
oh i see, is that bankstown? i live 10mins from there lol
xolent, your 7500S should be shipped already as they've charged me with one pair of 7500S in the item list.
should be there in not too long, perhaps tomorrow or day after.
Cheers
Rianto
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
