Rda Rotors Group Buy - 5th & 6th Batches
Received my rotors today. Just want to double check that the rear rotors are the same for R33 GTSt and 300ZX TT which is what is marked on the box? :S
Yes, All 300ZX TT uses the same rear rotors as R33 GTS-t (Part no 908) - they are interchangeable.
  • Replies 113
Allright guys, for batch #6:
1. RB_n00b - R33 gtst full set 7693S & 908S rotors - payment received
2. Simonster - R32 late GTR front 7701S rotors - payment received
Just to make it clear how this work: I do not work for RDA, and I do not personally send the rotors to you. (I don't even get to see the rotors.)
I submit the combined order to RDA (as an SAU Group order), and they do all the delivery and arrange where and which warehouse they got the stock in.
I believe when it comes to shipping RDA do it in one whole batch of all of you (logically they should be doing it that way to avoid confusion). So if the others have received theirs, it's just a matter of days before they get to you. As you've given me your daytime contact (mobile) it should have been written down on the delivery docket too so the courier can call you if no one was home.
But if yours haven't turned up in the next few days I will follow up with RDA - from the past 4 batches usually it's because no one was home and the courier could not get call the recipient (phone not provided, wrong phone number supplied, not picked up, etc).
I'm still waiting for a couple more transfers to go through, some said are transferring tomorrow as well, so looks like at least monday or tuesday for me to submit the order. It's a lot easier if I submit the order for 5 or 6 people in one go, rather than 3 tomorrow, then 3 on Monday...
Some transfer (e.g. electronic from other banks) may take 2 days to appear that's another reason for me to wait...
Monday evning update:
3. alexk - R32 GTR front 7926G & rear 908G - payment received
4. Fra22 - R33 Gtst front 7693S - payment received
5. xolent (welcome back) - 7500S & 478S - payment received
6. babia - R33 gtst rear 908S rotors - payment received.
7. IanB - R32 GTR (early) - pending payment
8. Deceeve - R33 Gts-t 7693S - payment received
To prevent delays to others who have their payments cleared, Group Buy #6 is now closed.
Batch # 6 will be submitted some time tomorrow afternoon. Will give you guys update in this thread tomorrow...
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
