hi guys
i have got a major problem and i really need advice ASAP Being a chick with a skyline its seems that every mechanic will do anything to rip you off. I have recently gotten my brakes and rotors replaced and now i have them sqeakin really bad. They are my front brakes sqeakin like hell. They sprayed some anit sqeakin still didnt work and paid heaps for NOTHIN they put new pads in aswell as putting new rotors on. They are still sqeakin hell bad and getting worse.
WHAT HAVE THEY DONE TO MY CAR OR WHAT HAVE I DONE TO MY CAR :)
https://www.sau.com.au/forums/topic/142243-sqeakin-brakes/
hey ....
the problem is easy....... u are using a metal brake
to solve ur problem u need to use a ceramice brake
i use Bendix General CT cost about $45 a pair
they r stand cheap brake
but the work the best and yes the will stop at 200km+
https://www.sau.com.au/forums/topic/142243-sqeakin-brakes/#findComment-2649556
Go do a track day that always gets the noise out of my brakes
good idea.
though this begs the question - did j-baby bed his brakes in properley?
j-baby - try this (check via the search button... hint hint, newbie:
Find a nice stretch of road, and apply the brakes as hard as possible without locking up from 100+ kph (110 is the legal limit) to about 10 kph. DON'T STOP - just brake hard. make sure you release before
repeat it a few times...
https://www.sau.com.au/forums/topic/142243-sqeakin-brakes/#findComment-2650838
I got bendix top range ???? its crap and embaressing. its not hot to be a chick driving a nice skyline and brakes are sqeakin really LOUD
What pads have you got in there?
I myself am having this problem, tried everything but am taking it in to Racebrakes to get it checked out.
https://www.sau.com.au/forums/topic/142243-sqeakin-brakes/#findComment-2652381
Ever since they changed my rotors and pads it has sqeaked. They fixed it for 3 days then it has gotten worse. In the begining it was rock in my calipers but now its beyond that and im running out of options.
could be brake dust, or maybe the backing plate could be touching the rotor, could be a rock in the caliper, Is it only when you apply the brakes?
https://www.sau.com.au/forums/topic/142243-sqeakin-brakes/#findComment-2652407
hey j- baby i had the same problem when bought bendex ultimates, pissing me off so i bought some CRC brake quiet from autobarn, bout $9.
all u do is apllie to both sides of the pads and let it dry, then whack back in! i did it bout 9 months ago and still no noise
also its red and like paste sorter drys rubbery
Edited by ali-turko
https://www.sau.com.au/forums/topic/142243-sqeakin-brakes/#findComment-2652415
thank god im not the only one. im in perth so im gonna have to search where tgey are coz we dun have autobarn here :blink:
https://www.sau.com.au/forums/topic/142243-sqeakin-brakes/#findComment-2652440
pretty much straight away coz i have to reverse out of my drive way and its starts from there. it sounds like metal to metal but im not convinced it is. i dunno what else to do :blink:
do the brakes squeal all the time, or just till they warm up ?
coz cold brakes squealing is very common.
https://www.sau.com.au/forums/topic/142243-sqeakin-brakes/#findComment-2652451
I had the same problem as most skyline drivers. The best fix for the squeeling brakes is to go and buy a couple of cans of brake cleaner and some crc anti squeel (red silicon).
1)pull pads and anti squeel shims
2)clean the shims, pads, pins and caliper with the brake clean. (make it all look like new)
3)roughen up the surface of the rotor with some 80grit sandpaper and do the same to the pads.
4)on the REAR ONLY use the crc anti sqeal, put it on the back of the pad and down the outside edges of the pad. (the rear pads have a lot of lateral movement and by doing this it minimises this movement and therefore less sqeeking).
5)Put the brakes all back together.
I use bendex advance as they are constructed from organic material rather then metal.
https://www.sau.com.au/forums/topic/142243-sqeakin-brakes/#findComment-2659727
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
