Thought I's start a new thread Erica.
To celebrate the return of the CHEEKY to the streets of our good city, there is a suggestion of a cruise tonight.
I'm keen as mustard for a cruise, although a little weary about police presence on the roads this weekend.
What do you people think?
https://www.sau.com.au/forums/topic/14233-late-notice-cruise-tonight-18-april/
*in my best upper class english voice*
Jolly good show ol' chap! errr.. chapess? Frightfully sporting of you I'd say.
Originally posted by CheekyR32
bah humbug to u all.. im going to take one (a defect) for the team.
Cruise first, then drink later! All pubs are shut today anyway!
I think the fuzz will be more focused on the country areas tonight.
Besides, we could all try to behave ourselves & obey the road laws for once!!!
Is this cruise just for us skyliners or are other scooters coming?
Guest Miss_Nismo
no drinking for you mister!!!! unless it's herbal tea!!!
hehehe, when we got to hungry jacks, I was tempting munro with some of my maccas. I noticed he kept running away from me, or maybe its just tn. Well this is the last cruise the camry will be in, hopefully next time the cefiro be out to play.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
