I own a bell something, paid a decent price as well. It now lives in a draw in my garage waiting fro me to decide wheather to reinstall it. I dont know; i think these things are like weight benches...you get all enthusiastic about the purchase and when you get them you use them for a while then they end up as an expensive dust collector. I found that even on "country" mode i still got a lot of false alarms. I prefer to scan the road side, remember the hot spots, watch the traffic and just be a bit more selective in when i stretch the GT-Rs legs. Still...its you cash >_<
Buy one local...not sure about OS radar frequencies. Best check with legallity of owning one and where to place it on your car, each state is different
https://www.sau.com.au/forums/topic/142368-radar-detector/#findComment-2650715
Yeah i've heard a lot about those BELLS one, i even heard of one that work with just plug in your cigi socket.
The oversea frequencies, i have no idea but its not my $$ either :woot:, its for a mate oversea.
Thanks
https://www.sau.com.au/forums/topic/142368-radar-detector/#findComment-2651007
Khoa
I had a Bell 900i when I lived in Perth. Radar detectors are legal over there and are great to have. Most places in WA stock them and you can buy them legally as well.
Over the years ive seen a few of em work and the old stuff is shit and gave a lot of false readings.
Id say anything new these days would work perfectly. They cost anywhere from 700 to 1000 dollars.
Ohh and Laser - yes radar detectors have ALWAYS picked up laser so I dont know what ur on about.
https://www.sau.com.au/forums/topic/142368-radar-detector/#findComment-2654540
they sell them at tandy/dicksmith
uniden brand they are on special awhile ago for $190 reduced from 300 and something.
if you want to sus some out check out american ebay, www.ebay.com they have alot to chose from so it is a good place to compare brands
https://www.sau.com.au/forums/topic/142368-radar-detector/#findComment-2670838
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
    • Gee she looks a bit rear heavy in that first pic! Sounds like a great project with the kids, but as I guess you know R series stuff is getting hard to find and pre that is pretty much impossible these days
    • Thanks GTSboy. I will inspect the valves actually, is this something I can do while they are still in the head? The block/bores don’t look bad to be honest hey, I can still see the cross hatches in the bores and they still measure 86.5mm. I’m not sure how to measure the installed ring gaps but I will do that and take it to someone who can.
    • I’ve had the same headache with my lowered car, scissor jack first then floor jack every time. Ended up grabbing an extra-low profile aluminum jack (about 70mm entry height) and it finally slides under the lip without drama.
