  • Replies 59
RB25 DET HEAD COMPLETE (including Inlet manifold,Coils,Centre Cover,Tappet Covers) $600
You still got this? Is it in good condition, what year engine (series 1 or 2) and does it have VCT?
still got this item
and sorry everyone
i havent been all there since someone tried stealing my r33 and smashing it 100 metres away from the workshop
but all items have been sent now
if items are not seen by friday please let me know
all items sent via tnt
hey dude, where are my brakes?
hello sorry everyone
tnt are tracing the brakes,plenium and Slimvlts parts
all three packages are traced to the depos
ill ring everyone 2morrow afternoon and let them know where everything is
first time this has happened
ummmmm
i said ill give them to you if i find them
and i didnt but im being nice and once the new ones come in hopefully this week i will send u new ones
im not knocking you mate, your a top bloke, im just a bit frustrated as you said you had posted them and last time i called you said you were going to chase them up and find out where they were and call me back in 10..... now your not answering my calls or sms.... i just want to be kept in the loop, bit frustrating when i was told they bolted straight on and then i find out i need spacers, hub rings and new nuts which i expected at the least..
i'm gonna have to agree with haysey, i'm still waiting for my brakes and i liked to be kept in the loop too, co could you plz pm the con note number
All new items have been sent via post
tnt lost the other items
Bump
all items must go
After the Standard R33 GTST WING S2 does the LED light work also has everyone got there parts is it safe to buy?
Thanks
John
3 people havent
but will either have a money order returned
or there items there by friday
thanks
and i do have the wing
the led works
if u want it organise your own frieght as im having bad luck with mine
thanks
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
