  • Replies 72
and what production years were Series 1 and Series 2?
I'm guessing;
1998-2000 Series I
1998-2002 Series II
yes/no?
Does anyone have Series II 2dr images?
Series 1 = 1998 - 2000
Series 2 = 2000 - 2002
My 34 is a 3/2000 and is a S1 so im guessing the SII came out from about june 2000 or so
the one on the right is not standard either, its got the nismo 300km/h speedo! and perhaps nismo centre gauges too although its blurry.
Thanks for all the info guys.. appreciate it.
Few years ago i brought a lemon s1 R33, had it for a year but it took me months to sell it, had too many problems. I was told the car had been in a major accident in japan (i was the first oz. owner) by a panel beater when i took the car in for a small spray job. Thank god, i got rid of the car for the same price i brought it..
With my next car, i will be doing my h/w and hopefully I'll come across a clean healthy black 34.
What was the production years for 34's? 1998 till 2000? Isn't that a bit short? So V35's begun in 2001 ?
Can some one tell me what on earth Xenon head lights are, lol i have no idea what they are or what they do.
Abo Bob
From the site you gave above.. what i've noticed is theres two different interior styles.. is the left one optional and the right standard?
Forged..
Thanks for the info :happy:
R34 GT-S, is this a series 1 or 2? .. such a beautiful colour though :) Its a pity this colour didn't come with GT-T's
Oh but it did.... in series 2 (I'm fairly sure)
I've seen the odd Bayside Blue series 1 but I've never been sure if they came with that colour from factory
Want to see hotness.... picture a midnight purple GT-t
Forged..
Judging from the pics, the front bar and steering wheel are definately S1. And yes, the GTT's did come in Bayside blue. One of the forum members has one.
My god.. that s2 bar does look shocking, you would expect the s2 bar to look better but a nice after market should fix all that up.
I'm hooked on this bayside blue color.. even if they did come with that colour from factory in s2 gt-t's id presume they still would be very rare to come by
Edited by pretender-
r34 gt-t's came in TV2 Bayside for both series I and II but only for series I's built in 2000 like mine
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
