  • Replies 47
i got in trouble for having one mounted on my dash apparently u arent allowed stuff on your dash
there goes my soft toy collection :)
yeah because it blocks your view apparently
i would have just span some shit like "yeah but so is the rear view mirror...and the steering wheel...and the frame of the car... but people can move their heads you know to see around it."
on the other hand its probably best not to say that.
Edited by Bloodlust
It is apparently an obstruction or distraction for the driver, but you can have the unit mounted on the windscreen if you turn the display off. The current BEL range you can do this and still get the audible/voice alerts so the display really isn't needed anyway.
If the cop wants to say it's a visible obstruction then just move it to the drivers side corner of your dash and tell them that it isn't taking up anymore room there than their in-car K band radar antenna... if they are happy to remove theirs then you will do the same!
  • 4 weeks later...
i recently bought an el-cheapo whistler 1732 detector...my 2 cents
1. driving on highway...beeped twice (possibly from handheld) coz about 1km after..2 cars were pulled over by cops for speeding -dectector was on city mode with all bands turned on
2. detector was on quiet mode...beeped once passing a petrol station...no beeps after ...300yards on..there was a tripod mounted radar....made a u turn...and drove past the radar again ....detector did not give off a signal...u turn again...drove straight past the radar...no signal..but the guy was fiddling with the radar so it prolly wasnt turned on
2 hours later...drove past the radar again...still just the single beep from the petrol station...turned and drove past again...cop was dismantling the radar..so couldnt test further
anyone know what band the tripod mounted radar uses?
Multanova's are Ka band and are supposably the hardest to detect since there so low power. IIRC there on the higher limit or just out of Ka band because they drift so much (and hence aren't that accurate...), the wideband detectors do really well against them.
I bought a shit cobra detector off ebay and it doesn't go off until your right next to the thing... its probably just your detector being shit. The cheap ones are really a waste of money for use with multanova's.
Dan, lasers are only used as handhelds. The tripod thingo's (multanova's) are all radar still. I'm pretty sure those camera's they stick in wheely bins are radar aswell, lidar makes it harder to get all the lanes at once.
GODTHRILA, I need to come see you to do some testing :happy:
Do you have a lidar gun at your work? I have a 'concept' I'm keen to test :P
GODTHRILA, I need to come see you to do some testing ;)
Do you have a lidar gun at your work? I have a 'concept' I'm keen to test ;)
The handheld lasers can be mounted to a tripod for further accuracy... they set these up a lot near Mandurah so I am told.
fr0st, just come and see me, we can test your "concept" with our laser
The multinovas are set up and operated by people who are outsourced. They are not official police officers ad have no standing to detain people. All they can do is call for the police.
I just thought they were trained/qualified cops... my bad ;)
I've never seen a tripod being used before in Perth. As far as I'm aware the max distance they can use lasers at is 400m and still have it hold up in court. Probably wouldn't need a tripod for that, but I haven't used a laser gun before so I can't really comment.
Can you pm/post you business address? It only lists a PO box on your website
Cheers ;)
GODTHRILA, what would you recommend as a good value for money (cheaper ;)) radar detector?
sorry to jack the thread.... but keep an eye out in the for sale section... I might be sorting out something for the forums sooner than you can say "two all beef paties special sauce lettuce cheese pickles onions on a sesame seed bun"
Cheers ;)
I've never seen an eskimo before so they cant exist
or maybe I havent been around enough :)
ok my bad...it was an outsourced person (i.e: no copper uniform...and sitting in a white 4x4....think it is the multinova's ...laser/radar....damned if i knew...bloody thing looked like a friggin missile launcer waiting to blow up any hoon
so what do u guys recommend for detecting multinova's? ...or do they generally trigger off the detector only if its targeted at ya?
    • Thanks, I'll give that a go. Hard pass on the steel bushings though 😄
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
