firstly what is the difference between bar & plate cooler and tube & fin? what are the performance gains/losses? also i will be upgrading my intercooler shortly and am after a 600/300/100mm core size with 3" end tanks. where is the best place to get one of these? all i can find is kits for various cars. not after a cheap one either. thanks..
https://www.sau.com.au/forums/topic/142985-intercoolers/
search, search, search
its been covered a million times before
the main differences are drag vs track use
both have advantages and disadvantages for each use
what core do u currently have and what do you hope to achieve?
https://www.sau.com.au/forums/topic/142985-intercoolers/#findComment-2664116
Im after a FMIC upgrade from stock on my R33. I have read all the links above and still cant seperate them. The bar and plate seems to be easier to get my hands on and cheaper. Im after a cooler that is good for a couple of runs at the drags but also is being effective to cool over long periods of driving, as i drive an hour to work and from work every day. This heak soak mentioned for the Bar and plate, is it going to be an issue over say a 2 hour drive? is it still better then the stock? Im just after something for Around 200kw, bit of drag, but more importantly something that will work best for everyday use. Thanks!!
https://www.sau.com.au/forums/topic/142985-intercoolers/#findComment-2665889
nismo god after reading the trhreads i can safely say you would be after tube and fin. bar and plate should definately out perform the factory cooler.
paulr33 u think so? what the problem with going too big? can get a good price on a second hand hks one 600/300/110 but seems a lil large. just dont want to have problems down the track and have to change piping etc..
https://www.sau.com.au/forums/topic/142985-intercoolers/#findComment-2666388
If it's for dragging (and you're going to enjoy trying to get 400rwkw to the ground) then throttle response is less important so bigger piping would not be a hinderance in that respect and can only be better in terms of flow.
But... (and I am purely talking out of my arse here).. the restriction of the system is only as much or little as the most restrictive part. In other words, what plenum and throttlebody are you using? Don't bother going any bigger than that.
Also I think that changes in restriction aren't helpfull either. Ie, from restrictive afm (for egsample only) to big piping to small throttle body. You might as well have had piping the same size as the smallest one of those 2 in the first place.
And finally for general reference; Bar and plate = cooler, tube and fin = flows better. You trade one for the other.
https://www.sau.com.au/forums/topic/142985-intercoolers/#findComment-2667604
spend the money elsewhere
Agreed, i think most of these 600x 300x 76 cheap intercoolers really are fine for 600hp. ive made 327rwkw with a stuffed r32 gtr cooler(looks like some kids ran their finger along all the fins)Realistically they are all basically similar, about 10 times bigger than the stock one so none of these would be too small.
https://www.sau.com.au/forums/topic/142985-intercoolers/#findComment-2667679
When GTR's with stock coolers make a lot more than 350rwkw pretty easily.
I reckon it leaves the door open to anything that size or bigger will do.
If your dragging (auto) then it really wont matter, manual it might more-so.
https://www.sau.com.au/forums/topic/142985-intercoolers/#findComment-2668801
abo bob currently i am using a greddy plenum with a rb25det throttle body (need the greddy adaptor). there is a pic attached. the thing i am worried about is the piping and throttle body (2.5") being too small as well as the cooler. dont want to get the thing going then realise its not cooling to the levelit should be..
https://www.sau.com.au/forums/topic/142985-intercoolers/#findComment-2670294
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
