seen a seller on ebay sell low mount stainless steel turbo manifold for rb 20 for buy it now price of $250. seller is monster performance claiming it bolts on, 2.6mm wall thickness, equal runners...
any opinions on them, i know ppl quiver wen they here ebay performance parts but there are ppl buying it so there must be user out there.....
thanx
https://www.sau.com.au/forums/topic/143001-rb20-turbo-manifold/
link?
ebay manifold have gotten a bad rap on here over the years
i have never used one myself or met anyone with one, so can't really comment, but would like to see a picture of hte equal length runner design
most low-mount ones i see have the runners join at different lengths and i dont' really like the look of it personally
yeah the runners arnt individual equal length, looks like 2 main pipes goin to the flange with others welded on along the way.
they claim power increase and blah blah but i suppose u only get wat u pay for, my biggest concern was the 'bolt on' part, i've found that with most performance parts unless its the genuine item then most copy cats have sum sort of problems with fitting.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
