  • Replies 152
Posted Images
yeah, but the problem is once you acheived the goal of putting pants on, you've failed to change them for the last 6 months. i guess now you know how to twist your pants around in order to use the fly at both the front and the back.
but I do confess you are a good lookin bloke. nothing wrong with that. i'm not camp. i swear. ask mark, I've knocked him back dozens of times.
https://www.sau.com.au/forums/topic/143129-movember/page/6/#findComment-2697500
