I encourage everyone to stay the night.. or two at wakie if they can!
last time we were there we got up to plenty of drunken antics the night before.. and even more so the night after!
I will still be going down to watch as I believe team QLD may be making another special appearance!
  • Replies 92
Posted Images
Yessir
I have back up this time too, Team QLD may even take line honours (Not me but Evocam)
hmm....tempting, if im not entering Kandos Street machine and hotrod show I'll be there, wont find out for a little while though
Come on Chris gotta go mate and have some more fun like at Oran at the Mcgill day that was some pretty awesome sideways action going on. The zed should be sweet by then and running the slicks too
Should be a great day
Hi All,
I will be coming down with EVOCam (previously GTR Cam on these forums) from Brisbane. We will hopefully be staying at the track as after the long drive we will need as much rest as possible (Read while Cam sleeps I can finally have some Jack and coke as I will drive most of the way...).
Please come and say hi, we will have the EVO 8 MR with APC stickers and the silver Hilux with the plates Stuck Up...personal joke.
Should eb an awesome day. We went twice last year, first time with a black EVo 8 Aust delivered and then with the MR before melting a piston...
Hopefully this time we can have as much fun as the EVO days there (and yes I drive a skyline so I like to give the driver/mate a good ribbing!!!)
Cheers
Neill
Edited by Bobjones
I believe they do!
I'll let mikey will tell you the info
I am comming down to watch for the day.
can anyone give me a lift?? dave? ando?
if not, no dramas, the proton will make the trip down there!
WTF33R - the meeting point is the BP petrol station on pac highway at pymble at 4 45 am. to then meet up at 5 30am at the ampol truck stop at crossroads in causula ( start of hume highway) with the autoasports guys.
pm me to organise this.
I believe they do!
no probs. :)
whens everyone leaving? i spose id better get the day of eah. (sat that is )_
ill have both camera's there but no mount for in car stuff as had been too busy being on holidays to have one made up but cant wait to see wakefield raceway for the first time ,
just a quick one who is odds fav for the day ?
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
