ok guys ill be putting a larger cooler in my car soon if i dont sell it and i was wondering if anyone could give me a few pointers on removing the factory non gtr front bar???? im pretty mechanically minded...i could nut it out but a few pointers are always handy.......:)
https://www.sau.com.au/forums/topic/14340-front-bumper-removal-on-a-32-gtst/
If you lived in Sydney i could show you a car park with cement sleepers all over the place, like me you are guaranteed to hit one when nudging forward after reverse parking into a spot.
... so then select reverse, and RRRRRRRRRIIIIIIIIIIIIIIPPPPPPPP!!!
voila no more front bar. :D councils:mad:
im in the same boat... i wanna modify a standard bar to fit a fmic. first though i have to find a standard bar. ive seen a few cars with modded std bars that have had the opening extended all the way up to the top of the cooler. looks quite good. i saw one on meggalas site. good lcuk with it all
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
