  • Replies 131
I'd do Wollongong but it's too far for most.
My suggestion is Thursday 30th. Slide will be down. Will Col-GTSX still be here?
I will come.
There is a good pizza and pasta place near me in Sutherland, plenty of parking...
Im happy with the 30th :)
I would like to catch up with Slide and meet Col-GTSX :P
Awesome :no:
And I dont mind south for dinner :)
Yiannis in Wollongong - I know its a long shot, but who knows.
Great greek food - souvlaki for 2 is teh win!
Yeah sorry the gong is a bit far for us :no:
But you should come to the dinner on a Saturday night :)
pretty sure will be one in December :P
I will come.
shire :P
j/k easier for me anyway...better take down the dice then :no:
Edited by mr 32
sorry Bec, beat you to it!
but i still say ours are better than what we saw!
haha you haven't seen dave yet... he shaved the beard and left the mo! lol
oh and Jess, Col will be here on the 24th... I'll keep you updated on what's happening there... but we'll more than likely head down to The Ranch for a few quiet drinks and some dinner.
30th is good for me too, doesn't matter where abouts. We can car pool the North Shore folks.
Yep we can car pool for sure
thanks
I'll leave my boxing gloves..and you can leave your dice :verymad:
LOL
I need suggestions
*Sticks thumbs out to hitch a ride...
I need suggestions
please people
Indian
Chinese
Thai
Italian
Russian
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
