Hiyas
I urgently need a couple of pieces of interior for my 32 gtr...
firstly the under dash fuse box surround and panel, and secondly the centre console middle brace (pictures attached below of the pieces I removed).
Dont like the screw holes. wanna replace it this week ;P
Thanks
-D
http://cgi.ebay.com.au/Nissan-R32-Skyline-...Z1QQcmdZViewIte
thx rocky
while ive placed a bid on that just in case, im more after something I can outright buy :P cheers for the link tho dude
-D
no worries  :) Although remember, if you win the auction you have to buy it.
But its worth waiting at that price... most wrecking places will charge you something like $300 for it.
Edited by Rocky88
after a few bits for the interior....
-a manual center console (as my gearbox died im doing a manual conversion)
-the center air vents for an r32 (not broken ones :D )
-inside door handles for an r32 (mine are faded would like new ones)
-r32 GTR rear seats (i've got GTR front seats and would like the rear to match)
-r32 pass. front seat floor mat for a 2 door (the ones that came from factory that say SKYLINE on them, i've got all the others but that one for some reason :s )
-also, still looking for some new brake rotors. need the fronts more then any of the others but may buy all 4 for the right price!
thanks
kye
Hrm mine are faded too and I'm gonna get some spray paint next week and do them (in black) if you wanna take yr old ones out I'll do them at the same time
-D
yeah i can get them shipped over here. And there are 34 stuff to. ive come to a total of around 1k delivered for most of my interior in carbon hehe
I see a couple of pieces that I'm after Luke, what do I gotta do to get you to import them for me mate?
-D
ah so these are what your brother was talking about.
can you get craig to msg me when he plans on getting a few things over? ill most likely take manual center consol surrond thingo and maybe the door handle bits too.
pay less on shipping with more :D
WANTED
Late model R32 GTR V-Spec......must be reasonably good condition.......must be an Aussie delivered model
PM with pics, details & price please
I dont think the V-spec's were aus delivered. Only aus delivered GTR's were the 1991 batch of 100... rest are grey imports (can anyone confirm?)
-D
would be close to it Ben, heres the specs:
To celebrate the success of the GT-R in both Group N and Group A racing, Nissan introduced the Skyline GT-R V-Spec ("Victory Specification") car on February 3, 1993. The V-Spec added Brembo brakes and a retuned ATTESA E-TS system to the Nismo and N1 packages, as well as 17" BBS wheels with 235/45/17 tires. The V-Spec has a list price of ¥ 5.260 million.
Finally on February 14, 1994 the Skyline GT-R V-Spec II was released, with the only change being wider 245/45/17 tires. Total production of the V-Spec I and II was 1,453 and 1,303 units respectively.
I want one of those please
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
