looking for some 17" wheels, must be 17x8 front minimum 17x9 rear minimum
prefer 5-7 spoke lightweights but let me know what you have
spending money around $800ish
have some 17x8 and 17x9 work equips here with tires. front legal and rear 80%+
1 may need resealing and is leaking.
come have a look and make an offer.
The defect doesn't really bother me, if I was going to be a defect worry wort I wouldn't have this style of car, I'd buy an Exel lol, I'm just after a style that 'looks' like its meant to be there, and don't want to molester my GTR at the same time by removing things here and there.
But bump to the A Pillar - and boost gauge and stoich gauge :P.
^^ You obviously have never had your defected to discover what an absolute nightmare it is to get off defect.
My advice would be to bin the idea mate, as the very first cop you go even remotely near at night will defect you - as A pillar gauges stick out like dog's balls (especially when they are lit up at night).
found some other ones i like a bit better, trying to get in contact with the guy but will let you know soon! :P
It actually sounds offensive, probably fun for the first 3 sessions hey Chad? :(
Hell yeah, thing is a RB26 with aftermarket turbos and straight pipes sounds about twice as loud as Carls old screamer, there's probably a few people at Mallala on Saturday who would probably agree :banana: So probably best i make it a little quieter and fit some kind of muffler.
Edited by DSTROY
After a 3inch or larger rear muffler to put on the skyline for track day, must be in reasonable condition, prefer jap brand cannons.
Cheers.
i removed a 3 (or was it 3.5?) inch kakimoto cannon from my old exhaust. had some minor damage that was welded up but I'll call mark from ET and see if he hasn't thrown it out yet
-D
-D
Awesome thanks, if he hasn't got your old one ask if he has any old ones laying around while you've got him on the phone :(
Awesome thanks, if he hasn't got your old one ask if he has any old ones laying around while you've got him on the phone :rolleyes:
He wasnt sure if he still has it as he does periodic cleanouts, but he said to come along Saturday morning and have a nosey around to see if its still there - are u free sat morn?
-D
Hell yeah, thing is a RB26 with aftermarket turbos and straight pipes sounds about twice as loud as Carls old screamer, there's probably a few people at Mallala on Saturday who would probably agree :P So probably best i make it a little quieter and fit some kind of muffler.
louder than my screamer.
OMG that must be loud.
ok ill pass :devil:
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
