Being a GT-R you will need same width and tyre width all round,
I'm 90% sure the same rolling diameter cannot be acheived even if you run the same width tires etc.
Plus its bad for understeer which GTR's already have trouble with.
^^ wanna do mine? other wise its going to precision diff, to cost me an arm and a leg :cool:
dude its easy as. will take you a while tho depending on how you are with your knowledge and tools.
trust me you should be able to do it yourself. and for sweet fa. ill be at u pull it tomorrow getting my parts and then to combine and mini spool. give me a yell if you get stuck.
Hey guys, after a stock r33 gtst fly wheel
condition: any
Prcie: im easy, what they worth?
pm me
cheers ash
Cearing out the garage again in time for the new project
r32 front heater core, all air con piping and air con pump with bracket. basically everything u need.. $140 ONO
rb20 alternator. $40
rb20 crossover pipe with bov. $80
standard rb25 engine mounts with no bushes. $25
rb20 rubber intake pipe. $25
rb20 turbo. was leaking a bit of oil but minimum shaft play $60
rb20 front fan, not sure wat its called, runs off the engine. i think its called clutch fan? with the plastic cover around it but covers got crack up top. $40
rb25 standard clutch $25 or if u want a week ill have a flywheel aswell and u can have both for $90
rb20 exhaust manifold. looks ok condition. $25bux
some random blue/black drift brand steering wheel. good condition $15
txt or ring me on 0428851616 or pm me
cheers
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
