needed by tomorrow
r33 front bar series 2
r33 rear bar
r33 left hand series 1 fender
r33 left hand side (passenger side) headlight
let me know
cheers
Got a rear bar for sale if you want it. Also have a set of S2 fog/indicator lights for the S2 front bar if you need. PM'd you :(
i upgraded to gtr in my 4door and honestly didnt feel much at all, removed and got brand new whiteline with links, for the extra coin its much worth it =)
i have a s13 track car, there is nothing in my back end and i mean nothing that bitch is light as, so therefore gtr swaybar will do something, i used to have a 32 dr and i kno how heavy the arse is haha
he doesnt have a 32 four door
u kno what i got mate :P
wasnt having ago bud, just speaking from experience.
gtr rear swaybar wont do shit unless you replace all bushes new atleast.
And Mitch i never said he had a 4door i was just saying what i installed it in, also i done the same in my ceffy again with no change really.
Edited by PROXIMITY
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
