My printer just died but i have ALOT of ink cartridges left so i was wondering if anyone has an old working printer?
Compatibility models. Please let me know, kind of urgent.
i560, i8500, i865, i9100, i950, i950D, i990, i9950, iP3000, iP4000, iP4000R, iP5000, iP6000D, iP8500, iP9950, MP750, MP760, MP780, S800, S820, S820D, S830D, S900, S9000
