WTB :
Drivers side Front indicator for a 32, the clear ones preferably, doesnt need to be tho. And if u dont want to split the pair, may consider buying both depending on price.
Also, I'm needing a globe holder that holds the H1 bulb in the 32 headlights. Yes, I have the shit 32 headlights.
Funny fact is that a 4 door R34 is NOT the perfect family car - my S15 even had more room for a baby seat in the back - and my V35 KILLS IT. When Tyler was little and in the back of the 34 he could easily reach the back of the drivers seat to kick and annoy the piss out of me. However in the V35 there is literally a foot between his feet and the back of my seat. Go figure.
I attempted to have passengers in the rear of the R34 a few times (once for a wedding), and the driver and passenger front seats have to be stupdily forward and nearly touching the dash to even fit legs in the back. Poor design for sure (but sexy cars, no doubt).
i beg to differ though andrew, the 34 backs are pretty spacious, ive had 3 fatties in the back but the s15 if someone was in the back they had to put their feet in the opposite footwell to be comfy...
