I get my license back real soon now... 5 weeks away so i need to start thinking about getting a new whip so...
if anyone has a VT (or onwards) stationwagon in decent condition well maintained, tow bar, etc etc that they're looking at selling or even thinking about it swing me a PM and I might be interested!
Cheers all :)
Anyone got an inlet manifold to head gasket lying around for RB25???
Need one like urgently. Nissan don't have one in stock, and hoping to fit it by tomorrow (or asap) to finish tuning my car. My boost leak is apparently coming from a leak between cylinder 5 and 6 due to blown inlet manifold gasket :(
PM me please :)
needed by tomorow S13 power steer line
hey need tomorow the short metal power steer line between the back of the rack and the knuckle on the pinion
its on the back of the rack itself and is only about 300mm long, its mad short
i crushed it when i put my engine back in the car or taking it out one of the two
but i have a private track day monday and need it changed
ADELAIDE please call on 0425313447
PM me please :)
All sorted now, thanks to nicr4wks :thumbsup:
Hey guys,
WTB: Subaru Forester 03-04 Model
Model: XS Luxury or XT (Turbo :thumbsup: )
My missus had a car accident the other day and now she needs a new one and it has been on the cards for a while.
Anyone know of one for sale or if you have one pm me and go from there
Cheers, :cheers:
Matty
Hey all
Was wondering if anyone has a climate control system for their r33 laying around in good working order as the one in mine, the off button decided to break (i beleive its an s1)
(not important but if anyone has any mirrors for an r33 in working order, fold in and out in the red wine colour, dont have car with me or colour code that would be sweet)
antenna doesnt go up or down so i need one of thoes in good working condition also
cheers, aaron
Hey all
cheers, aaron
lol same problem hey?
my off button broke aswell thought i found a site on ebay in adelaide that sells them
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=360322358382&ssPageName=STRK:MEWAX:IT#ht_3348wt_1139
that should help ya out mate
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
