surge tank fittings are usually placed in the middle of the tank making the fuel inside just splash around etc
Swirl tanks are usually round with fittings placed on the end causing the fuel to "swirl" inside, there for fuel will always be available to the inlets/outlets.
Marko go a swirl pot instead of a standard surge tank.
Outlaws in the city can help you, thats where i got mine but in a 4L
Exactly what im looking at if nothing comes up by Friday, was going to put a baffle in a standard tank to stop it from splashing around otherwise tho. Ill give outlaws a call tomorrow, cheers for that. The one im looking at is on the net $100 for 2L tank
Just to clarify on the fuel pump bit, as I just found out, ill be needing a minimum of a bosch 044 or equivalent and at least 2L capacity surge tank :( if anyone has anything let me know asap otherwise ill have to ditch more cash at the hunk and go buy new stuff this week :wacko:
Bosch 044 and bracket acquired, thanks a bunch to frankyp11 absolute champ!
URGENT -
WTB - series 1 r33 type m front bar with indicators, and rear pods, preferably in the burgundy stock colour. would save a lot of headaches. still message me if you have in other colours.
will pay cash on pick up.
- few hundred dollars depending on condition and whether or not the front bar indicators are included. very keen for a quick buy so if you have this stuff message me.
Contact - msg me anytime on 0421549607
WTB:
1: Bottom half of cluster surround or the entire trim
2: Drivers kick panel under the cluster surround
3: Trim that goes around the gearstick boot.
4: Main headlight switch
All parts are for a R32 GTS-T
PM me details or txt me on 0433 522 234
Cheers Tim
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
