wtb: black 18" or 19" rims that will fit a v35 and clear brembos. Im not very sure about offset, etc. so got no idea how to calculate or estimate the correct size. Initially, i wanted some 18" drift teks but got told that they are unable to clear brembos without bolt on spacers.
cheers
beepee
http://nissansilvia.com/forums/index.php?showtopic=457088
well buy the rims and take em in to get powder coated which is cheap and have black center with polished lips. will have bucket loads more style than cheap doriteks and you might actually get some respect with it ;)
WTB: Set of R33 stock side skirts and rear pods preferably in series 2 silver but will take any colour if in good condition. Must be in good condition, i.e. no cracks or major damage. PM please.
Thanks
hey buddy, those are some gangster rims you got there, but I'm interested in black rims, similar spokes to drift teks. thanks for the reply tho.
drifteks are f**king gay - i do not understand how people love fake wheels
WTB: R32 Dash, GTR fenders and someone on here had a Venom boost gauge a couple weeks back?
I have a dash in my garage I removed 2 yrs ago - has a couple screw holes on the left side of the cluster where a big gauge was mounted, and it has the bubble in the typical location
good if you want to retrim it or just need a dash for a track basher, but not so great if you're looking for a replacement for a showcar
PM me if you're interested
-D
hi i am after a air pod kit with the adaptor pipes from afm for a r34 gtr,not fussed on brand but the kit iv been looking at is the apexi as in link below,if any one has a kit 4sale or knows were in sa to get them would be great.
http://www.kudosmotorsports.com/catalog/ap...line-p-481.html
go down to repco/autobarn, buy a pod adapter for an r34 ($30) then wander down to motorquipe and find yourself a 3A brand air filter ($30-$50)
Done.
Edited by SkyHi_33
Unfortunately being a year 12 student I sadly dont have enough coins for some decent rims.. thus I have to resort to drift teks for the time being. However, my plans are to get work xd9.
thanks for your thoughts tho.
beepee
nothing wrong with teks, theyre a good drift wheel, cheap enough to replace if you stuff it up and cheap enough to afford as a set of spare rims for track. they look decent too.
id rather replace a cheap rim and spend more money on skid tyres then having to sit around saving up to replace a killa jap wheel
Edited by SkyHi_33
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
