looking to pick up standard air box cover and brackets etc,want to customise for pod,looking to get bracket that holds up powersteering fluid box,one on left suspension pillar pm me please
Wanted to buy or trade.
Looking at replacing 2 X Bridgestone B500si 215/50/17 91V on my Stag with 235/45/17's with good thread. The Bridgestones have about 50% (or less, i don't know how to tell really) thread left. If replacement tyres are good, some money your way even, negotiable.
Reason: Got 235/45/17's at the back and I need the same sized tyres all round.
Thanks.
Thanks.
they dont have to be the exact same width just roling diameter ive had 225x45x17 up front with 235x40x17 up the rear and were fine
Yeah i know, but although my newish 235/45/17's and the 215/50/17 were within the rolling dimension tolerance, i'd rather they be the same as after a little bit of spirited driving, i get the little "fart" noise when I turn the car off. I figure in the long run...
Anyone got a r32 boot lid with no spoiler???
Preferably white.
Any colour is better than nothing.
And also, looking for a low racing seat with low mount rails to suit 32. But has to be in top condition! Prefer black.
Or r32 GTR seats, maybe 33 if they bolt up. (Not sure)
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
