hey guys i just orderded a gt30r internaly gated turbo i was wandering if there are many peaople out there with this turbo and could share there experiences, power wish, and if there responseive? laggy etc supporting mods to make there power. preferably on a rb25.
cheers sam
https://www.sau.com.au/forums/topic/143748-garret-gt30r/
damn really thats awesome ive been to one tuner here in perth and said nothing but negative comments about the turbo so i got a bit worried and made this post they said i will have endless problems with boost, do you have any problems with boost and can iask what other supporting mods u were running with this turbo
cheers sam
https://www.sau.com.au/forums/topic/143748-garret-gt30r/#findComment-2683804
The int gated housings are only new to the market... i'd sad hardly anyone would have one on there car
so there will be no results as such.
If it performs like the ext gate version (which it should) then there is a zillion threads about those :(
https://www.sau.com.au/forums/topic/143748-garret-gt30r/#findComment-2685136
you have to order a 1 bar canister for the gcg gt30 for the internal wastegate actuater or a hks one , otherwise she will struggle to hold much over 17psi of boost. that is why external wastegated gt30 are better than internal wastegates. i should know ive run both on my rb25.
https://www.sau.com.au/forums/topic/143748-garret-gt30r/#findComment-2685149
Just like the XR6 turbo (as they are essentially the same turbine housing but running a smaller wheel).
Throw a decent actuator on it rated close to the boost you intend to run.
Its silly to use a 6-7psi actuator when you intend to run 12psi+.
https://www.sau.com.au/forums/topic/143748-garret-gt30r/#findComment-2685860
haha yea id like to know , and i have bad news really wanted to get all my parts fitted including this turbo but due to the discontinued power fc's not sure what engine management im gona get, still trying to find a power fc i hav my car booked in, in 2 weeks but if no power fc i cant really get my car tuned :P
https://www.sau.com.au/forums/topic/143748-garret-gt30r/#findComment-2688986
supporting mods needed:
-aftermarket ecu
-aftermarket injectors (nismo 550 or 740cc direct bolton fit for r33 rb25)
-aftermarket fuelpump (i see ur looking at getting a 044 fuel pump, i would say go for something like nismo or tomie as they are direct bolton takes not more than 30mins to install one)
you should also consider buying some rims if you only have stock rims (reason why is with aftermarket rims you can run larger tyre size which can help with traction)
Aftermarket clutch
and if you have money left over, good shock and spring setup, camber kit for the rear (so u can get rid of that negative camber when u lower the car), good brake pad upgrade ....
good luck!
gt30 seems alittle big for me thou ..
ps check ur topic in wa about pfc, as i can help
https://www.sau.com.au/forums/topic/143748-garret-gt30r/#findComment-2688995
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
