TOPIC SAYS IT ALL HELP ME!
PHOTOS PLEASE
I NEED TO RUN MY BOOST SENSOR WIRE INTO THE CABIN FROM THE ENGINE BAY.
THANKS GUYS....
its a series 2 r33.... the japanese know how to piece together a bloody confusing fire wall :-P
cheers please help!
pics of inside wire and outside would be helpful
pic below i just felt like adding :dry:
:P
in the engine bay, right over the drivers side of the firewall, there's a small gap, you cant see through it, but you can feed the hose through. it should come out above your pedals inside the cabin.
that's where i got mine in.
i know it would help if i had pics, but i havent.
CHEEERS
I am not sure if my cars the same as yours as I have a big ass ABS unit taking up the passenger side..
Your description had me looking around the area shown in the picture below... i cannot seem to find a hole though...
it is doing my head in...
HELP
pics would b great.!
dude, give me an hour. i gotta run out for a min. i'll take a pic when i get back.
sweet as!! thanks... send us a pm once threads updated cos my email makes a bloody loud beep :huh:
you impatient bastard. lol
here, this is the best i can do.
when you look at it, it doesnt seem like you can pass through from there, but just feed the wire in and it should go. i managed to get the hose through without much problem.
HAHAHAH WHAT A SICK c**t!
THANKS MAN! CHAMPION....
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
