my car is a r31 ti skyline and iam not sure about somthing atm its running at 11.1lts to the 100km and i can do 535km till the tank is empty. that info is all from the on bored computer and was worndaing does that sound right
thinks :(
https://www.sau.com.au/forums/topic/144032-r31-ti/
As I don't own an R31 Ti, this cant be specific, but!
In my collection I have a U12 Pintara Ti auto and that returns about the same as your R31 and it is a KA24E.
My old MX83 Cressida returned the best figures I could get, on highway cruising was 12L/100 and about 15/100 around town.
These 2 cars are similar in weight but the R31 has less HP as in 114Kw Vs 142Kw.
My latest Cressida on a recent trip to Melbourne, returned 10.5L/100 for 2011 Km and just got back from the Gold Coast and for 2312 Km returned 11.33L/100, so for over 4000K I got 10.9L/100 on average.
I think this is brilliant considering the cars are their respective top of the tree luxury versions, complete with all the trimmings & fruit salad.
I am though, questioning your computers calculation of 535k which tells me it says it only has 50L in the tank which is incorrect. I would guess it would have between 60 & 70L
Cheers, D
https://www.sau.com.au/forums/topic/144032-r31-ti/#findComment-2688230
Your fuel consumption sounds about right. I have a Ti as well as a couple of others :happy:
The average consumption in traffic should be around 12 or 12.5, and on a trip should vary from 9.8 to 11.5. So you are right on the ball. The fuel tank is 65 litres, but the trip computer only takes into account around 50-55, so even your trip computer is right, because it has a 10 litre reserve.
Your trip computer has a hidden function as well. If you press the hour and the minute buttons together, it will tell you how many litres are left in the tank. This is very accurate, and will help better with distance to empty, taking into account all the fuel instead of just what the trip computer thinks it has.
So all in all, your trip computer is working accurately (the way it was intended anyway), and your fuel consumption is on the money.
https://www.sau.com.au/forums/topic/144032-r31-ti/#findComment-2689312
  • 4 weeks later...
thinks :)
i had an R31 sil with the 5spd manual and i used to get 8.9-9l/100k for long distance and around 9-10.5l/100k in and around the city and i used to get ~700k per tank {well 698ish} and even my GXE3 got similar figures.. try cleaning air filter and maybe new plugs and stuff cause my sil used to go heaps better afterdoing that.. lol that poor car ran the same oil for 1 year and a half :P over 30000ks but it still kept going hard they are wicked cars.. ive recently bought a WGNC34 Stagea cant wait to take that on a run up to cairns
https://www.sau.com.au/forums/topic/144032-r31-ti/#findComment-2762166
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
