hey.
in need of new front and side skirts vertex or uras bodykit for my ceffy. also need front guard to divers side.
want and new/used engine rb20det at good price must have less then 120.000 kms
looking for quickly an intercooler pipe that goes from stock pipe over the fan and down. need quickly.
please let me no asap
https://www.sau.com.au/forums/topic/144113-needed-ceff-parts-and-rb20det/
got an engine here in sydney for $1000ono. comes clean loom and computer. also got the gearbox off it for $500. all in top notch. or $1350 the lot.
Edited by bloodsword27
