Hey All,
I own an r34 gtt with xenon headlights and the bulb on the passengers side has died.
I'm having difficulty opening the headlight to remove the dead xenon bulb.
There's a larger circular piece behind the bulb area that looks like it can be rotated to remove but it won't budge.
Can anyone please provide some steps on how to replace the xenon bulb?
Thanks in advance!
Ed
https://www.sau.com.au/forums/topic/144291-xenon-bulb-replacement-on-r34-gtt/
Hi there, the way i opened mine was just to rotate it counterclockwise.. maybe you have to use a little bit more force? I'll be putting in xenon bulbs tonight/tomorrow afternoon so i'll double check..
while I'm at this. the way to get the bulb out is just squeezing the bottom bit (where it connects to the wire) together yeah?
cheers
Hey All,
Thanks in advance!
Ed
I changed mine yesterday..
There should be a little screw before u turn the cap.. u should see it..
after you unscrew take the cap off..
After you should see like 2 clip pushing the light inside just unclip that and you can change your bulb..
Hope that works for you..
hmm mine didn't have screws..weird but i changed the bulb.. in about 20mins and that include fiddling with the battery to get my hands behind de lights of the driver side.
woohoo.. not hard at all.. I'm just waiting for night to test out the white light. So Deejay how's it going then?
hey i have a 34 but no xenon, (i think). how do i know if i have it? is there a power supply or something like that?
I am pretty sure 99.9% that all R34's have xenons. If you look at your head light it says the word xenon below the bulb on the main headlight not your parkers like you have on in the picture in your sig.
Drew.
Hey guys,
I was finally able to replace the bulb, the circular cap was screwed on incorrectly making it difficult to remove. :laugh:
Now my problem is, it's a different colour to my old bulb. :teehee:
Anyone know where I can order another bulb in melbourne?
I'm looking for a D2R bulb, 6000k temp.
What is a decent price for one?
I saw some on ebay but they are some crappy taiwan brand. I'd prefer the philips hid bulbs
Cheers!
all r34s brought in under sevs shouldn't have xenons, they're removed at compliance. People do put them back in though.
Hi,
Thats interesting as someone else mentioned that, so far all the R34's I have seen had them so I assumed that they kept em, do you know why they had to be removed? Is it cause they are so bright or something cause I know the ones I had are super bright.
Hey guys,
I was finally able to replace the bulb, the circular cap was screwed on incorrectly making it difficult to remove. :)
Now my problem is, it's a different colour to my old bulb. :)
Cheers!
hey there mate.. if you head over to the dealer's side of the forums, batmbl and sullivanB (i think that's both the nicks) sells those xenon bulbs.. not expensive.. check it out
guys i tried replace my headlight xenon today(the small purpleish one on the side, on headlight), im having diffculties to take off the whole unit, i unsrewed 4 screws..and there something else still stiking to it..
cheers...
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
    • Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
    • The other trick I've found with wrinkle black is to put the can in hot water for a bit to warm the paint up, and to pre-heat whatever you're painting. It'll be interesting to see if you pick up any power with the intake, following with interest. Got a proper lsd for this?
    • Plazmaman 76mm Pro Series, done. Data to back it up, I posted up somewhere here a few years back
