Hey Guys,
I cant even believe that I am puttng this up, but its time.
The car was just featured in IGNITION DVD and Fast Fours and Performance Cars Magazine.
I am taking Expressions of interest, and please no time wasters.
The car currently makes just under 500 RWHP at the wheels with a mild pump fuel tune at 18psi
Add c16 and an extra 12 pound boost and you do the maths
The motor is built with 3.0L Bottom end with Arias Pistons and Argo Rods
The motor has done 4,000kms
Genuine buyers only please, PM me for a full list of modifications pics and details
Car has over $50k of Modifications, with out labour
These are
BODY
Custom House of Kolors Candy Violet Respray
Bomex Rear Ring
400r front and Rear Bar
Veilside Side Skirts
Pumped front and rear guards
Carbon Fibre Bonnet
$10k
WHEELS
19x8.5 front
19x11.5 Rear
Rays Engineering Volk Gold GT-c Rims
$5k
INTERIOR
Recaro Front Seats
Modified Cushioned rear seats
Recovered in Yellow Italian Leather
Momo Leather steering wheel
Momo Gear Knob
Defi Gauges - Boost, Oil press, Fuel Press
Autometre Shift light
$8k
ENGINE
RB 30 Block
Arias Pistons
Argo Rods
ARC Bearings
Nismo N1 Oil Pump
Heat Treated Crank
$8k
RB25 Ported and Polished Head
HKS Cams 256 and 264 deg
HKS Cam Wheel
$4k
GT35/40 Roller Bearing Turbo
Stanic external Wastegate
Custom JnJ Billet Throttle Body
Custom JnJ Plenum
$5k
Custom JnJ Exhaust Manifold
3.5 inch AB Flug Exhaust System
$2k
Custom JnJ Billet Fuel Rail
Siemens 770cc Injectors
Twin Bosch Fuel Filters
Custom JnJ Surge ank mounted under Car with 2 x Bosch 911 Pumpa
1 in tank Bosch 911 pump
SX fuel Regulator
$6k
Autronic SMC computer
Autronic CDI
$3K
CUSCO 1.5 way diff
Thats about all I can think of at the moment, If I have missed something please ask.
As you can see i have spent well over 50K of mods without including Labour
Im asking for offers around 40K
Cheers
Dave
post-10752-1165313549.jpgpost-10752-1165312680.jpgpost-10752-1165312777.jpgpost-10752-1165312867.jpg
Edited by weapn
https://www.sau.com.au/forums/topic/144327-500hp-pump-fuel/
Why not list mods and price up here so you dont have to keep typing it out in PMs???? Would help to see if people are even in the ball park for price or not.
Cheers
https://www.sau.com.au/forums/topic/144327-500hp-pump-fuel/#findComment-2695051
Cheers
Only interested in genuine peopl, as you can appreciate you get a lot of tyre kickers and "dreamers" with out sounding rude.
https://www.sau.com.au/forums/topic/144327-500hp-pump-fuel/#findComment-2695815
Okay,
List of modifications are as follows
BODY
Bomex Rear Ring
Carbon Fibre Bonnet
$10k
WHEELS
19x8.5 front
19x11.5 Rear
$5k
INTERIOR
Recaro Front Seats
Momo Gear Knob
$8k
ENGINE
RB 30 Block
Arias Pistons
Argo Rods
ARC Bearings
Nismo N1 Oil Pump
Heat Treated Crank
$8k
HKS Cam Wheel
$4k
Custom JnJ Plenum
$5k
$2k
SX fuel Regulator
$6k
Autronic CDI
$3K
CUSCO 1.5way diff
As you can see i have spent well over 50K of mods without including Labour.
When you add this on the whole car including the purchase owes me between 80 to 100K
Edited by weapn
https://www.sau.com.au/forums/topic/144327-500hp-pump-fuel/#findComment-2696477
Hers some more pics.'
Will try to get some of interior and engine bay over next day or so.
Can also see it in Ignition DVD and fast fours mag where there is engine bay shots and interior shots and full specs.
The Car is in Show car condition and at the moment gets drivn one Sunday a month when im not working!!
Edited by weapn
https://www.sau.com.au/forums/topic/144327-500hp-pump-fuel/#findComment-2696481
david, i cant believe your selling it, this is honestly the most beautiful skyline ever, the thing only comes out the garge once a month if that.
im sure who ever buy it you'll be sleeping in the garge with it for a while.
jai.
https://www.sau.com.au/forums/topic/144327-500hp-pump-fuel/#findComment-2719600
jai.
Thanks Jai
Its getting harder to let it go.
Getting alot of Pms, people wanting to come see it, but no one coming up with the cash yet.
https://www.sau.com.au/forums/topic/144327-500hp-pump-fuel/#findComment-2726161
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
