If you want to disable attessa and ABS on a 32 you can while coasting. walking pace is enough. turn the ignition off. (caution straight roads are best for this. also loose power steer brake assistance etc) then turn ignition back on and restart. ABS and 4WD lights will stay on ie no attessa no ABS. makes the car quite different to drive. the system will restart the first time you come to a complete stop or when you turn ignition off then on again.
https://www.sau.com.au/forums/topic/14438-attessa-switching/#findComment-302472
here is one for ya
if you have a fuse cut (it wont cut the abs)and turn off the 4wd now when you reconect the fuse while the engine is still on 4wd wont come back you have to turn off the engine and reset to get 4wd back
if you use the roling tech above you loose abs as well however you dont have to reset cause it does it when you stop
pete
https://www.sau.com.au/forums/topic/14438-attessa-switching/#findComment-302754
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
