Got some of these gauges for sale:
Smoke series gauges from $39, also have water temp, oil temp, oil pressure, vacuum, volt, ait/fuel ratio gauges and 360 degrees boost gauge, all prices are different.
-Auto Gauge 270 degrees 52mm Boost Gauge(PSI) $39
-Auto Gauge 270 degrees 52mm Boost Gauge(BAR) $39
EL series gauges from $29, also have water temp, oil temp, oil pressure, vacuum and volt, all prices are different.
-Auto Gauge EL 270 degrees 52mm Boost Gauge(PSI) $29
-Auto Gauge EL 270 degrees 52mm Boost Gauge(BAR) $29
Auto Gauge gauge holder to fit all kind of gauges from $13, please leave part number.
Autogauge turbo timer
-Auto Gauge Mini Box Style Auto Turbo Timer $47
-Auto Gauge Pen Style Turbo Timer with Voltage Display $55
*All new in box, come with all necessary hardwares and English installation manual.
*Please try not to PM me unless something personal, just leave a message in this post if you're asking for price or question, I'll get back to you asap, so I can keep this post update, thanks. :(
Edited by cookiebear
  • Replies 61
All PM replyed, and if you've any question please leave it here, and I really perfer not to PM me, I rather answer everyone's questions in here, unless something private, otherwise my post can be lost in 1 day, thanks. :(
  • 4 weeks later...
wraith_skyline, for the smoke series boost gauges, you can get them in bar or psi, they're $39 each + postage, and I have another smoke one which is a 360 degree boost gauge (psi) for $65, same as the one you see in the photo.
lineskee 33, still have your number and all your details, will keep you update when the money arrive, thanks for buying. :)
Hey mate,
have you got anymore of those Smoke series boost gauges $39. i assume its the one in the first attached pic? just a question..how much do they read up to? i assume 30psi? and for anyone who have used them before...... are they accurate?
kind regards,
Edited by R33LIN
ODessA, if you're buying them together, they're $90 + postage, usually oil pressure is $34, oil temp is $34 and water temp is $31, you save $9. If you're getting the gauge holder as well, I can give a a better price too. Let me know soon, thanks.
R33LIN, it reads up to 30psi, and I still have them for sale. Where are you from?
how much for a smoked series oil temp and a smoked series afr together posted to Northgate, SA, 5085? Cheers, Andrew
Nightcrawler, oil temp $48, air/fuel ratio $61, I can get both send out to you for $110, usually $5 postage per gauge interstate, may be cheaper for same state. Let me know soon, I can get them to you by tomorrow. My number is 0402 452 455, message/ring me if you're interest, thanks.
Nightcrawler, not really, even the EL series oil temp is $35, prices are just depend on what gauge it is, and the smoke series air/fuel ratio gauge is the second most expensive gauge I have. Anyway, let me know if you change your mind, usually people get more discount when they order 3 gauges/items more, so $110 posted to you is not really bad. Anyway, let me know soon. :teehee:
ODessA, didn't know if you get my sms, but I'll keep an eye on my account and I'll update you with sms again when I get the money also when I send the item, thanks for buying. :P
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
