Hi guys,
Interested to know if an RB20DE clutch/flywheel is smaller in diameter and 'hat' size to a RB20DET clutch/flywheel?
I gather that a RB25DET clutches are the same physical size because RB20DET and RB25DET engines can use the same flywheel.
Can I use a heavy duty RB20DET clutch in a RB20 atmo gearbox?
Fixxxer :(
https://www.sau.com.au/forums/topic/144490-rb20des-vs-rb20det-gearbox/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
