Your Choice
29 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 167
everybody wants to poke fun. last time i checked, my mini did around the same 1/4 mile time as a stagea. brad's being the exception. he cheats.
oh yeah MRO, im in parky. he he. really close.
ill make the effort im just getting tired of always having to catch the throttle cause the stupid thing wont idle properly.
hmm that would have been a biatch to fix then kylie..did mitchy do all the work for ya? :)
Heath wont do you get a lift with someone that has a spare seat and then you wont have to take the mini???
hey mitchy its a good job u are coming along in a skyline as u can attract all the cop attention away from my stagea :) i removed the rear muffler tonight and only have a single 3.5' straight through muffler on it and its farkiiinnnnn stupidly loud and will sure get the wrong attention if we happen to see mr plod along the way :)
i need to buy another 3.5' muffler but not till the tune on tuesday so ill have to live with it as it is :) it sounds more like a rotary than a 6 cylinder with the cams lol
oh im excited to actually bring the stagea along this time and cruise with another 10 of them :)
so what time we meet at hillarys then???
is it old age :)
FIRST POST HAS BEEN UPDATED WITH DETAILS OF THE CRUISE SO PEOPLE DONT HAVE TO SEARCH PAGES FOR ANSWERS TO TIMES AND MEETPOINTS
TAKE CARE GUYS AND SEE YOU THERE :)
lol hope you're going to set your alarm this time Kirstie :no:
ps: yes Mitchy did all the work after we got the studs removed professionally - cause them things are a biatch to get to when the motor is still in the car!
This was gonna be a message telling you I am bringing a mate in his R33 but he burnt his clutch out last night LOL!
Anywhoo, is there any chance we can get the map (before the meet in Murdoch) in case we get there a little late?
(I have a wife and 2 daughters so this is a distinct possibility!)
i can send you the word document and you can print it out on your end if you like...
*have put the cargo barrier thingy in my boot so i wont forget to give ya that either*
do the same for me please.
i got a 21st the nite before so arising early might be a drama with a hangover and all. he he. ill do my best though
TYPICAL BRITTISH CAR OWNER - STARTS MAKING EXCUSES AT LEAST 2 DAYS OUT :)
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
