Group Buy # 3 Arospeed Adjustable Cam Gears, By Popular Demand
I'm not scared off by this at all I'm just getting a pair instead of the EX gear only. For the price they are might as well go for the pair anyway.
  • Replies 240
Posted Images
Hi Dom,
When you have time could you start a list so we can see how many there are being ordered so far?
My count is.. 20 gears
hey mate! send me a pm with banking details!
i bought these for my r33 not that long ago, excellent qaulity, now i have a GTR im keen to get another set! and yes i did get power increase out of the exhaust side wheel, infact 13rwkw more!
so to all the people wondering, exhaust is required to dial up some neagative/positive timing! i went for 2.5* negative! worked well. but talk ot your mechanic, i wouldnt recommend doing it yourself! hope we got more than 20 people! thanks r33kid... your a champ and veyr good to deal with!!!
I WOULD LIKE A BLUE SET FOR MY R32 GTR - RB26. THANKS...
Ok Current List
1) DivHunter * IN FOR A PAIR
2) Smooth * IN FOR A PAIR
3) Mike_ * IN FOR 1 GEAR
4) NV N01 * KEEN FOR 4 PAIRS
5) Nabil * IN FOR 1 GEAR
6) cln * IN FOR 1 GEAR
7) R33fourdoor * IN FOR 1 GEAR
8) Dspita * IN FOR 1 GEAR
9) Betz * IN FOR A PAIR
10)75coupe * IN FOR 1 GEAR
11)xRHETTx * IN FOR A PAIR
12)Giffo * IN FOR A PAIR
13)femno * IN FOR A PAIR
SO FAR WE HAVE 26 GEARS
Giffo my mate got 21rwk on 2psi less on his GTR. Because the gears gave him a precise tune.
c'mon people, get your orders in quick, these are great quality and excellent design! lightweight and they look good!
bets price on the net people. get in and grab a bargin!
cheers
Garth
Sorry its still $160 PER PAIR
READ THE POST.
26 Gears = 13 pairs
Also this is a price break i was given if more than 10 pairs are ordered.
10 - 15 pairs $160
15 - 20 pairs $150
20+ Pairs $140
This is down to $140 per pair, not far off the starting price of a single gear! :D
Ok Current List
5) Nabil * IN FOR A PAIR
14)StockyMcStock * IN FOR A PAIR
15)STRYKR 33 * IN FOR 1 GEAR
16)teazn_r33 * IN FOR A PAIR
SO FAR WE HAVE 32 GEARS = 16 PAIRS
Edited by r33kid
Ok Current List
can anyone please confirm if i need both for a r33 S2 96? i have been told i only need the exhaust cam gear. Thanks!!
Ok Current List
17)Darkboy *IN FOR A PAIR
18)Nismo_God *IN FOR A PAIR
19)Musky *IN FOR A PAIR
SO FAR WE HAVE 38 GEARS = 19 PAIRS
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
