Group Buy # 3 Arospeed Adjustable Cam Gears, By Popular Demand
  • Replies 240
Posted Images
r22kid can you please confirm if i just need the one cam gear on the exhaust side? I have heard that i only need the exhaust cam gear. Thanks!!!
Ok Current List
1) DivHunter * IN FOR A PAIR
2) Smooth * IN FOR A PAIR
3) Mike_ * IN FOR 1 GEAR
4) NV N01 * KEEN FOR 4 PAIRS
5) Nabil * IN FOR A PAIR
6) cln * IN FOR 1 GEAR
7) R33fourdoor * IN FOR 1 GEAR
8) Dspita * IN FOR 1 GEAR
9) Betz * IN FOR A PAIR
10)75coupe * IN FOR 1 GEAR
11)xRHETTx * IN FOR A PAIR
12)Giffo * IN FOR A PAIR
13)femno * IN FOR A PAIR
14)StockyMcStock * IN FOR A PAIR
15)STRYKR 33 * IN FOR A PAIR
16)teazn_r33 * IN FOR A PAIR
17)Darkboy *IN FOR A PAIR
18)Nismo_God *IN FOR 1 GEAR
19)Musky *IN FOR A PAIR
20)pimpenr33 *IN FOR A PAIR
SO FAR WE HAVE 40 GEARS = 20 PAIRS
Edited by r33kid
you just need exhaust side, but having 2 makes it look nicer, i run 2 in my r33.
Great stuff :(
We are 1 pair away from saving even more money! :(
How much longer 'til you end this groupbuy?
Are you gonna wait the full length or just get numbers up and then order?
Wait till its gets close to the closing date.
Great stuff :D
We are 1 pair away from saving even more money! :D
The only reason I was asking is cos I get paid monthly and my next pay isn't 'til the 15th or so?
Just checking to see if I would be able to participate or not?
hey r33kid, i have already placed my order for an exhaust side cam gear, can you change the order and make it a pair. It's for a R33 GTS-t and in blue please.
So are we back up to 40 gears?
Does that make it $150 delivered for a pair or do we need one more?
Yes we need 1 more pair to reduce the price to $140 a pair + freight
Ok Current List
Edited by r33kid
Down to $140 PAIR OR $70 SINGLE GEAR + $10 FREIGHT
Ok Current List
21)83nno *IN FOR A PAIR
22)bangahh *IN FOR A PAIR
23)#177 *IN FOR 1 GEAR
SO FAR WE HAVE 45 GEARS
Edited by r33kid
