Group Buy # 3 Arospeed Adjustable Cam Gears, By Popular Demand
THOSE WHO HAVEN'T PAID
6) cln * IN FOR 1 GEAR
7) R33fourdoor * IN FOR 1 GEAR
16)teazn_r33 * IN FOR A PAIR
17)Darkboy *IN FOR A PAIR
20)pimpenr33 *IN FOR A PAIR
25)DaGr81 *IN FOR A PAIR
26)GTS-070 *IN FOR A PAIR
28)SKYR34 *IN FOR A PAIR
ALSO IF MEMBERS ARE STILL INTERESTED IN GETTING ON THIS GB YOU CAN DO SO, AS LONG AS PAYMENT IS DONE ONCE PAYMENT OPTIONS HAVE BEEN RECEIVED AS WE STILL HAVENT HAD EVERYONE PAY.
Edited by r33kid
  • Replies 240
Posted Images
update non payment list
Anyone got the link to the thread about these cam gears
specifically discussion on performance on rb25det?
I want to have a read
I'd like to see any info re performance gains pls????
hey mate! send me a pm with banking details!
i bought these for my r33 not that long ago, excellent qaulity, now i have a GTR im keen to get another set! and yes i did get power increase out of the exhaust side wheel, infact 13rwkw more!
so to all the people wondering, exhaust is required to dial up some neagative/positive timing! i went for 2.5* negative! worked well. but talk ot your mechanic, i wouldnt recommend doing it yourself! hope we got more than 20 people! thanks r33kid... your a champ and veyr good to deal with!!!
I WOULD LIKE A BLUE SET FOR MY R32 GTR - RB26. THANKS...
There you go
Pls add to the list... 1 pair blue for RB25.
I've sent an email to your address,
Please PM/email me bank details, and i will transfer $140+$10 tonight.
Edited by travb81
PAID LIST
1) DivHunter * IN FOR A PAIR PAID
2) Smooth * IN FOR A PAIR PAID
3) Mike_ * IN FOR 1 GEAR PAID
4) NV N01 *IN FOR 4 PAIRS PAID
5) Nabil * IN FOR A PAIR PAID
7) R33fourdoor * IN FOR A PAIR PAID
8) Dspita * IN FOR A PAIR PAID
9) Betz * IN FOR A PAIR PAID
10)75coupe * IN FOR 1 GEAR PAID
11)xRHETTx * IN FOR A PAIR PAID
12)Giffo * IN FOR A PAIR PAID
13)femno * IN FOR A PAIR PAID
14)StockyMcStock * IN FOR A PAIR PAID
15)STRYKR 33 * IN FOR A PAIR PAID
16)teazn_r33 * IN FOR A PAIR PAID
17)Darkboy *IN FOR A PAIR PAID
18)Nismo_God *IN FOR 1 GEAR PAID
19)Musky *IN FOR A PAIR PAID
20)pimpenr33 *IN FOR A PAIR OUT
21)83nno *IN FOR A PAIR PAID
22)bangahh *IN FOR A PAIR PAID
23)#177 *IN FOR A PAIR PAID
24)theevilworld *IN FOR A PAIR PAID
27)dmnt *IN FOR A PAIR PAID
28)SKYR34 *IN FOR A PAIR PAID
29)benjo *IN FOR A PAIR PAID
30)travb81 *IN FOR A PAIR PAID
31)1JRocket *IN FOR A PAIR PAID
Edited by r33kid
Edited by r33kid
Does anyone know of a link for installation instructions?
How easy is it to replace the cam gears?
r33kid - pls add me to your list, #29 - payment sent today!
Edit : Found this awesome thread which explains what is involved in installation :
http://www.skylinesaustralia.com/forums/in...showtopic=25899
Edited by travb81
Thanks for your patience, as I've been away over the break and clean forgot about the group buy. Pls check your PM's for my payment receipt.
Please note: Payment made for 1 x PAIR of gears (originally asked for 1 gear).
Please let me know if there is a problem adding the extra gear.
Once again, another superbly executed Group Buy.
Cheers, Mike
ill have to set a deadline, but ill just wait a few more days as people might be on holidays, i want to make it fair as this looks like the last group buy.
When is the deadline? eg the people who havent paid miss out?
No problem..
I'm going away on holidays today and HOPEFULLY they\ll have all paid by the time I get back.. (5th January)
Regards,
Sherwin
i was under the impression that the RB25 and RB26 have different cam gear offsets, thus you cannot interchange the two gearsets. can anyone confirm this at all?
if u look on the nengun web page it will tell ya that the hks gears are for both 26/25..
Were you got that impression is totaly false, there exactly the same.
RB20/25/26 AND C18 Gears are all the same.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
