Guest INASNT
Check out the Geremy Clarkson vidz on this site, for those that dont know him hes the host of top gear a uk car show.
The first 'no limits' vid has a Jun 1000hp R33 at the end which Jeremy fangs around an airport runway. Its the fastest road registered car in the uk being able to do 0-100 in 2.5 seconds.
http://carfreaks.b0nk.net/
Havent seen the other vidz, downloading now, but they will be farking sick 2.
If u are on 56k dont bother coz each file is a dvd-rip and are about 650mb each.
Enjoy
https://www.sau.com.au/forums/topic/14485-jeremy-clarkson-vids/
  • Replies 55
Originally posted by darK
i'm d/ling them and burning them for denham as we speak..
so.. maybe we can figure something out jay
Yepp, no worries.
Just the BIG ones (150+ megs) I'll grab off ya. The others I'll download over night with Download Accel. Should only take about 53 months !!!
Damn dialup :P
u want the "Jeremy Clarkson" ones yer?
Yepp :uh-huh:
I'm going to download the smaller ones (less than 150meg) that are in the root directory just to see what they are about.
There's also a few big ones in the Best Motoring directory.
I've had those 4 movies in DVDRip-DiVX format for a month or 2 now ;)
They are quite an interesting watch.
Edit: Just noticed the 'Best Motoring' rips, they'll be tonights download ;)
/slaps his ADSL Modem smoking with 30gb/mth.
Guest INASNT
how fast are u able to download with your asdl? I was getting 80+k/sec with my optus cable.
How much u paying for asdl and with who? i wanna change over 2 as 3 gig is fark all per month.
54k/s
$99.95/mth with Internode on the 512/128k FlatRate doing around 27gb/mth.
Getting 220k/s from this http site.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
